Results 1 to 1 of 1
Thread: Problems with selecting objects eg. Only able to select 1 object at a time.
    13,656
    Default Problems with selecting objects eg. Only able to select 1 object at a time.
    Only able to select 1 object at a time - the most likely reason for this behaviour is the current setting of system variable PickAdd.
    Below is taken directly from the AutoCAD Online Help File [F1] -
    Type: Integer
    Saved in: Registry
    Initial value: 1
    Controls whether subsequent selections replace the current selection set or add to it.
    0 Turns off PICKADD. The objects most recently selected become the selection set. Previously selected objects are removed from the selection set. Add more objects to the selection set by pressing SHIFT while selecting.
    1 Turns on PICKADD. Each object selected, either individually or by windowing, is added to the current selection set. To remove objects from the set, press SHIFT while selecting.
    Links:
    Autodesk Knowledge Base:
    ID: TS22407 - Objects removed from selection set when new object selected
    ID: TS22435 - Object selection modes explained
    ID: TS31472 - Object selection modes
    ID: TP5567612 - Having trouble selecting objects?
    AUGI Forum:
    Mysterious pick problem
    selection variable
    grips- no multiple picks
    Trim, copy, etc problem
    Unable to do multiple grip selections while holding down the shift key
    Unable to select objects via their Grips
    Trim command, only able to select one line at a time
    Trouble selecting multiple entities in AutoCAD
    Can't select more than one objects!
    selection command
    Unable to select more than one Object?
    Only able to select one Object at a time
    Unable to select more than one item...
    Can only pick one item at a time
    Selecting more than one object without having to hold down the Shift key
  1. PR31-2: Selecting The Right Objects Every Time In Visual LISP
    By Autodesk University in forum Computer Programming
    Last Post: 2012-11-24, 07:38 PM
  2. Can select only one object at a time
    By Capt. Computer Crasher in forum AutoCAD General
    Last Post: 2008-04-03, 01:58 PM
  3. Replies: 2
    Last Post: 2007-02-14, 07:13 PM
  4. Only able to select one Object at a time
    By c.gibleon in forum AutoCAD General
    Last Post: 2006-10-24, 01:50 AM
  5. Replies: 3
    Last Post: 2004-06-14, 06:50 PM
