Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Managing Multiple drawings in a single session
    100 Club jhohman's Avatar
    2003-08
    Spring Hill, Florida
    195
    Default Managing Multiple drawings in a single session
    Whenever you have multiple drawing open in a session of AutoCAD, you can quickly jump from one drawing to the next by holding the CTRL key and pressing TAB. This will cycle through available windows. Saves a little time from minimizing drawings or accessing them through the Window pull-down.
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Re: Managing Multiple drawings in a single session
    Please don't take this as stepping on your toes on this good tip for navigating thru opened drawings... I just wanted to add to this.... I used to use this same method but have been using doctabs for a while now, and I love it! It adds another row of tabs for each drawing open. The look just like the layout tabs...
    Here is where to get it...
    and a screen shot.
    Super Moderator rkmcswain's Avatar
    Earth
    9,747
    Also consider one of the many "Drawing Tabs" apps out there.
    Here is a free one as shown below
    R.K. McSwain | CAD Panacea |
    100 Club murrayc.49304's Avatar
    2003-03
    158
    The one I use is called DocBar which is available here http://www.cadwerx.net/?path=DocBar
    Last edited by Wanderer; 2005-07-13 at 07:15 PM. Reason: adding link to developer's website...
    2001-12
    St. Louis
    5,319
    Talking Re: Managing Multiple drawings in a single session
    Quote Originally Posted by jhohman
    from help TASKBAR -
    Set the TASKBAR command to 1 to display multiple open drawings as separate items on the Windows taskbar. You can then press Alt+TAB to quickly switch from drawing to drawing. If you prefer to display only the active drawing on the taskbar, set TASKBAR to 0.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    2003-08
    195
    That's all good stuff to use, I appreciate the additional input.
    Earth
    9,747
    Quote Originally Posted by mes0945
    I can't imagine why anyone would want a taskbar button for each open drawing. Different strokes for different folks I guess...
    I suppose Autodesk was just copying Microsoft's bad idea, which goes against their (Microsoft's) own definitions of MDI & SDI. Then again, does Microsoft even know what MDI is anymore?
    0,0,0 The Origin
    8,569
    I used AcadTabs for a while but I just use CTRL+TAB now. Less screen clutter.
    John B
    2001-12
    St. Louis
    5,319
    Quote Originally Posted by johnbogie
    I believe that when you have SP2 installed in Win XP, you can see a thumbnail of the file/drawing rather than just the program icon and name (correct me if I am wrong and this was available earlier), which I really like...
    Melanie Stone
    @MistresDorkness
    Technical Editor
    0,0,0 The Origin
    8,569
    Would you please expand on that. I've not seen it.
    John B
  1. 2007: Multiple drawings open with one cad session
    By Darren Allen in forum AutoCAD Land Desktop - General
    Last Post: 2014-06-19, 04:02 PM
  2. breaking multiple tab drawing into single tab drawings
    By steve.m in forum AutoCAD General
    Last Post: 2012-06-21, 04:58 PM
  3. AutoCAD LT 2006 - Opening multiple drawings within same session
    By lazer2go87184 in forum AutoCAD LT - General
    Last Post: 2006-11-30, 10:00 PM
  4. Replies: 6
    Last Post: 2006-11-13, 08:08 PM
  5. Allow scrolling of commands from multiple drawings in same session
    Last Post: 2006-11-06, 09:24 PM
