Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Managing Multiple drawings in a single session
    100 Club jhohman's Avatar
    2003-08
    Spring Hill, Florida
    195
    Default Managing Multiple drawings in a single session
    Whenever you have multiple drawing open in a session of AutoCAD, you can quickly jump from one drawing to the next by holding the CTRL key and pressing TAB. This will cycle through available windows. Saves a little time from minimizing drawings or accessing them through the Window pull-down.
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Re: Managing Multiple drawings in a single session
    Please don't take this as stepping on your toes on this good tip for navigating thru opened drawings... I just wanted to add to this.... I used to use this same method but have been using doctabs for a while now, and I love it! It adds another row of tabs for each drawing open. The look just like the layout tabs...
    Here is where to get it...
    and a screen shot.
    9,805
    Also consider one of the many "Drawing Tabs" apps out there.
    Here is a free one as shown below
    100 Club murrayc.49304's Avatar
    2003-03
    158
    The one I use is called DocBar which is available here http://www.cadwerx.net/?path=DocBar
    Last edited by Wanderer; 2005-07-13 at 07:15 PM. Reason: adding link to developer's website...
    2001-12
    St. Louis
    5,408
    Talking Re: Managing Multiple drawings in a single session
    Quote Originally Posted by jhohman
    from help TASKBAR -
    Set the TASKBAR command to 1 to display multiple open drawings as separate items on the Windows taskbar. You can then press Alt+TAB to quickly switch from drawing to drawing. If you prefer to display only the active drawing on the taskbar, set TASKBAR to 0.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2003-08
    195
    That's all good stuff to use, I appreciate the additional input.
    9,805
    Quote Originally Posted by mes0945
    I can't imagine why anyone would want a taskbar button for each open drawing. Different strokes for different folks I guess...
    I suppose Autodesk was just copying Microsoft's bad idea, which goes against their (Microsoft's) own definitions of MDI & SDI. Then again, does Microsoft even know what MDI is anymore?
    0,0,0 The Origin
    8,570
    I used AcadTabs for a while but I just use CTRL+TAB now. Less screen clutter.
    2001-12
    St. Louis
    5,408
    Quote Originally Posted by johnbogie
    I believe that when you have SP2 installed in Win XP, you can see a thumbnail of the file/drawing rather than just the program icon and name (correct me if I am wrong and this was available earlier), which I really like...
    Melanie Stone
    @MistresDorkness
    Technical Editor
    0,0,0 The Origin
    8,570
    Would you please expand on that. I've not seen it.
  1. breaking multiple tab drawing into single tab drawings
    By steve.m in forum AutoCAD General
    Last Post: 2012-06-21, 04:58 PM
  2. AutoCAD LT 2006 - Opening multiple drawings within same session
    By lazer2go87184 in forum AutoCAD LT - General
    Last Post: 2006-11-30, 10:00 PM
  3. Allow scrolling of commands from multiple drawings in same session
    Last Post: 2006-11-06, 09:24 PM
