Results 1 to 6 of 6
Thread: How to use Layer names with spaces in
    2004-11
    55
    Question How to use Layer names with spaces in
    Hey everyone, i need a little help with making a custom button. Well I already have it made i was just trying to add some functionality to it and i hit a road block. What i want it to do is freeze 3 certain layers only problem is these three layers have a space in there name so it just stops when it hits the space and says it cant find the layer. so instead of finding the layer DELTA POINT it says it cant find the layer DELTA.... is there any character that represents a space.
    Thanks for any help
    2001-05
    Austin, TX USA
    2,201
    Default Re: How to use Layer names with spaces in
    Try putting quotations ( " ) around your layer name in your button.
    ex
    "DELTA POINT"
    0,0,0 The Origin
    8,570
    You could use an underscore in the layer names but -
    first try surrounding the layer name with quotes in the macro - "Delta Point".
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Thumbs up Re: How to use Layer names with spaces in
    Hello,
    I just did a command line layer freeze on a layer name with spaces. Use quotes (") at beginning and end of layer name(s). Hope you get it to work!
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Here's mine, mod as needed:
    LayerToggle.lsp
     (DEFUN c:def (/ |layer|)
       (SETVAR "cmdecho" 0)
       (COMMAND "._undo" "be")
       (SETQ |layer| "Defpoints")
       (layertoggle)
       (COMMAND "._undo" "e")
       (SETVAR "cmdecho" 1)
       (PRINC)
     (DEFUN c:dims (/ |layer|)
       (SETQ |layer| "dimensions")
       (layertoggle)
       (PRINC)
     (DEFUN c:dwg (/ |layer|)
       (SETQ |layer| "dwgtexture")
       (layertoggle)
       (PRINC)
     (DEFUN c:ga (/ |layer|)
       (SETQ |layer| "G-ANNO-NPLT")
       (layertoggle)
       (PRINC)
     (DEFUN layertoggle (/ |assoc62| |assoc70| |dcl_id|)
     ;;; need to define error code - not done yet.
       (IF (TBLSEARCH "layer" |layer|)
     	(PROGN
     	  (SETQ
     	|assoc62| (CDR (ASSOC 62 (TBLSEARCH "LAYER" |layer|)))
     	|assoc70| (CDR (ASSOC 70 (TBLSEARCH "LAYER" |layer|)))
     	  ) ;_ end of setq
     	  (IF (= (GETVAR "clayer") |layer|)
     	(COMMAND "clayer" 0)
     	  ) ;_ end of if
     	  (COND
     	((AND (> |assoc62| 0) (> |assoc70| 0))		     ;on-freeze
     	 (PROGN
     	   (SETQ |dcl_id| (LOAD_DIALOG "LayerToggle.dcl"))
     	   (IF (NOT (NEW_DIALOG "LayerToggle" |dcl_id|))
     		 (EXIT)
     	   ) ;_ end of if
     	   (ACTION_TILE "tn" "(setq |answer| 2)")
     	   (ACTION_TILE "ff" "(setq |answer| 1)")
     	   (ACTION_TILE "cancel" "(exit)")
     	   (START_DIALOG)
     	   (UNLOAD_DIALOG |dcl_id|)
     	   (COND
     		 ((= |answer| 1) (freezeoff))
     		 ((= |answer| 2) (thawon))
     	   ) ;_ end of cond
     	 ) ;_ end of progn
     	((AND (< |assoc62| 0) (= |assoc70| 0))		     ;off-thaw
     	 (PROGN
     		 (EXIT)
     	   ) ;_ end of if
     	   (START_DIALOG)
     	   (COND
     	   ) ;_ end of cond
     	 ) ;_ end of progn
     	((AND (> |assoc62| 0) (= |assoc70| 0))		     ;on-thaw
     	 (freezeoff)
     	((AND (< |assoc62| 0) (> |assoc70| 0))		     ;off-freeze
     	 (thawon)
     	(T nil)
     	  ) ;_ end of cond
     	) ;_ end of progn
     	(ALERT "\nLayer does not exist!!! ")
       ) ;_ end of if
     ) ;_ end of defun
     (DEFUN freezeoff (/)
       (PROGN
     	(COMMAND "_.-layer" "freeze" |layer| "")
     	(COMMAND "_.-layer" "off" |layer| "")
       ) ;_ end of progn
     ) ;_ end of defun
     (DEFUN thawon (/)
       (PROGN
     	(COMMAND "_.-layer" "thaw" |layer| "")
     	(COMMAND "_.-layer" "on" |layer| "")
       ) ;_ end of progn
     ) ;_ end of defun
    LayerToggle.dcl
     LayerToggle : dialog {
     	label = "Freeze/Off or Thaw/On" ;
     	spacer_1 ;
     	initial_focus = _no ;
       : row {
     spacer ;
     	: button {
     	  key = "ff" ;
     	  label = "Freeze/Off" ;
     	  mnemonic = "F" ;
     	  width = 8 ;
     	  fixed_width = true ;
     	  is_cancel = true ;
     spacer ;
     	: button {
     	  key = "tn" ;
     	  label = "Thaw/On" ;
     	  mnemonic = "T" ;
     	  width = 8 ;
     	  is_cancel = true ;
     spacer ;
     spacer ;
       : row {
     spacer ;
     	: button {
     	  key = "cancel" ;
     	  label = "CANCEL" ;
     	  mnemonic = "C" ;
     	  width = 8 ;
     	  is_cancel = true ;
     spacer ;
    2004-11
    55
    Thanks for the replys. It works great!
  1. 2015: AutoCAD 2015 doesn't like layer names with spaces and dashes
    By awander in forum AutoCAD General
    Last Post: 2014-06-19, 11:43 AM
  2. Room Names and Spaces
    By sjsl in forum Revit MEP - General
    Last Post: 2010-06-11, 06:22 PM
  3. Replies: 14
    Last Post: 2010-03-24, 05:13 AM
  4. Change Layer names to other Layer names via a script?
    By tburke in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:30 PM
  5. Using Layer names with spaces in them, inside of a Script
    By amy.chen in forum AutoCAD Customization
    Last Post: 2006-04-06, 03:53 PM
