Results 1 to 7 of 7
Thread: Attaching a tiff file
    100 Club MikeM4OSU's Avatar
    2004-02
    Tulsa, Oklahoma
    195
    Default Attaching a tiff file
    Hello everyone, I am having a bit of trouble. I have an excel file that has alot of formating to it. I have 31 of these to process, so bringing them into as a table will take to much time. My solution was to create an image to attach to my cad file. Here is my problem. I made a pdf out of the excel file and then opened in Photoshop and saved it as a Tiff. When I try to attach the image in AutoCAD 2006 and received an error "Image file unsupported". Has anyone been through this process or have any suggestions on why this has happened or a solution for me to try.
    2001-12
    St. Louis
    5,406
    Question Re: Attaching a tiff file
    Quote Originally Posted by mikem.65918
    how are you trying to attach it? using insert - > raster image?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2004-02
    Tulsa, Oklahoma
    195
    Default Re: Attaching a tiff file
    I using image attach. The files in question are all *.tif files.
    13,656
    Hi
    Maybe the following will get you going in the right direction (ignore the "Applies to:" list)...
    ID: TS67210 - Error inserting TIFF files: Invalid File Format
    Have a good one, Mike
    2004-02
    Tulsa, Oklahoma
    195
    Thanks Mike, but that did not work as well.
    I could stop if I wanted to Steve Johnson's Avatar
    2004-11
    Western Australia
    294
    TIFF is not so much a file format, but more a metastandard. This means there are many variants of TIFF, all of which may be valid, and only some of which are supported by a given software application. I suggest you open and save your file as a different variant using something like the free Irfan View (www.irfanview.com), then try again in AutoCAD. My experience is that AutoCAD will accept the following TIFF variants: Packbits and No compression. You can also use BMP, GIF, TGA or JPG.
    2004-02
    Tulsa, Oklahoma
    195
    Thank you Steve, I was able to use the tif file after saving it with IrfanView.
  1. 2013: Tiff file not allowing text to wipeout
    By KFullam346590 in forum AutoCAD General
    Last Post: 2013-01-03, 01:53 PM
  2. 2011: Binding XREF .tiff file
    By jberghuijs in forum AutoCAD General
    Last Post: 2010-06-10, 09:11 PM
  3. problem importing tiff file
    By timsea81 in forum Revit MEP - General
    Last Post: 2009-03-16, 09:45 PM
  4. convert .tiff file to .dwg file
    By cobra1964 in forum AutoCAD General
    Last Post: 2008-07-16, 03:56 PM
  5. Insert image file (TIFF) into an AutoCAD drawing file
    By snorcisa in forum AutoCAD General
    Last Post: 2007-04-15, 09:51 AM
