Results 1 to 8 of 8
Thread: How do show Similar Sections...
    Active Member -OTTP-Brembo's Avatar
    2004-06
    Darwin, Australia
    75
    Default How do show Similar Sections...
    I have a roof plan which I have taken a Section RB whcih shows a Truss to Wall connection detail. This section which references a 2D Drafting View.
    I would like to take another Section RC further down the wall which has a Similar detail.
    How do I do this and reference the same drafting view?
    2003-05
    5,153
    Default Re: How do show Similar Sections...
    If I'm understanding correctly, Section RC would be set to reference Section RB ( Check the box in the Options Bar _ " Reference Other View " and select Section RB as the view to be referenced. )
    Section RB has the callout to the Detail View .
    Quote Originally Posted by stephen.69615
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,285
    Instead of creating/drawing another "callout" select "Reference other view" on the options bar, then selecte the desired callout...
    HTH
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
    2004-06
    Darwin, Australia
    75
    That is what I am doing. But the Section mark that shows on the plan is also called Section RB. I now have 2 sections called RB. I want to know if I can call the new one RC ?
    2015-10
    2,285
    If you create a new section by referencing it to another, eg section RB, the the referenced section will become section RB SIM - I don't believe you can remame it...
    Cheers @blads
    2004-06
    Darwin, Australia
    75
    Me either. Doesn't matter though. I can live with this option.
    2003-05
    5,153
    If that were possible, when you clicked on the Section Mark RC, it would take you to Section RB.
    Might get confusing ?
    2004-06
    Memphis TN area
    7,048
    From my experience, a referenced detail that is similar to another detail always carries the name of the other detail, with a SIM label next to it.
    Think about the contractor who is using the drawings to build a building. He sees the RB section mark and goes to another sheet (or wheverever it is) to look at section RB. So if you have another section further down that is similar to RB, but you call it RC, the contractor is going to be looking for section RC. If you had both details drawn out, then there would be no need for a SIM label. Instead, you draw one detail, RB, and reference the other section as RB SIM and the contractor will (or should ) know what's going on.
  1. AEC-sections or similar "single"-section + sections without depth
    Last Post: 2014-11-14, 06:56 AM
  2. 2013: Parallel Sections Show as Callout
    By Limbatus in forum Revit Architecture - General
    Last Post: 2013-07-17, 03:38 AM
  3. SIM Sections don't show on plans
    By DaveP in forum Revit Architecture - General
    Last Post: 2008-08-15, 09:57 PM
  4. Get banding labels to show up on sections
    By briankeels in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-05-16, 04:44 AM
  5. sidewalks that show in wall sections
    By zach.emmingham in forum Revit Architecture - General
    Last Post: 2007-04-04, 06:22 PM
