Results 1 to 10 of 13
Thread: View Titles and Rotated Viewports
    I could stop if I wanted to Cathy Hadley's Avatar
    2003-05
    San Diego
    222
    Default
    I have many rotated viewports.... would like these to have view titles... below the viewport and with the stretchable extension line?
    I have created a viewtitle that is 90 degrees... works fine... Moves around nicely...
    Its the extension line that I can't seem to rotate? I tried adding a line into the Viewtitle... can't get it to be stretchable... then I thought... oh I'll just add a short line and then draw a line on the sheet to extend the rest of the viewport... well... no snaps to the end of a line nested like that...
    Please help... oh great Revit Gods...
    your humble Revit Servant...
    CZH
    2001-12
    Irvine, CA
    7,567
    Default Re: View Titles and Rotated Viewports
    Cathy,
    For rotated viewports I gave up on the stretchable line...you can put a line in, dimension it with a parameter, but then you've got no access to the parameter when you load and use it. Disappointing huh?
    Well, I use two different routes for view titles overall as a result. For projects that use NCS/UDS I have a symbol that is our detail box that I move the view title into (no lines, just text in the view title). Two other topics to review that I go into this are LINK1 and LINK2
    For simpler schemes, I opted for underlined text for the title so a line appears under the title but it is only as long as the text. Downside is these look different depending on the view.
    Just some thoughts for you...
    Oh, since we're talking about rotating views...you better be prepared that your other annotation objects that are visible in the view like column grids, section marks and elevation marks will be oriented differently and not necessarily following text orientation conventions.
    2003-05
    San Diego
    222
    Steve,
    Thanks at least it helps to know I should stop messing around and just move on ...
    I am going to add a line (4" or so) to all view title families so they all look the same and be done with it...
    As to the text rotation in sections, etc... doesn't bother me too much... at least not until you mentioned it.... glad to see you can re-orient all the tags to vertical tho ...
    CZH
    Active Member LMSmith's Avatar
    2003-07
    Cambridge, MA
    67
    You could also try rotating the crop region of a view instead of the viewport - this way your view titles will remain on the bottom - no need for a special family.
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    maybe a tutorial on this is in order? I just tried, and, though it looks like it is going to rotate, it doesn't. what gives?
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Greg,
    Try this:
    While in the view,
    1.) Enable crop regions.
    2.) Select (highlight) the crop region border.
    3.) Pick the rotate tool above.
    4.) Either type in the angle or drag the view around.
    5.) Readjust the crop region to show what you want.
    Works the similar with callouts. If you choose, you can turn off the crop region, and the view remains rotated.
    One issue, if you choose to type in the rotation angle or drag it around, elements within the view rotate opposite (+90 typed in rotates elements clockwise) what you'd expect.
    2003-05
    Emeryville, CA
    1,352
    My bad, I was trying this in an elevation, thinking it would be cool to be able to do exploded box style elevations on the plan sheet for design review on one of my smaller projects. So the plan would be oriented normally, and the elevations would appear to have "fallen away" from the plan...like the walls collapsing onto the ground. Anyway, I don't think this rotation trick works on elevations...
    2003-05
    Waterville, Maine
    1,748
    That would be neat.
    Have you thought of exporting the elevations out as .dwg, and then importing, placing, and rotating the elevation .dwg's around your floor plan.
    It'd be a pain in the a** to update.
    2003-05
    Emeryville, CA
    1,352
    Quote Originally Posted by andrewg
    That would be neat.
    yes...I followed your exact train of thought...PITA
    2003-05
    San Diego
    222
    Thanks, I never knew you could rotate a crop region... Thanks ... ops:
    Just the solution I need... Makes it much nicer now that the views and the viewports are oriented the same...
    Now to go back and rotate the tags back to horizontal...
  1. 2011: Viewports / Templates / View Titles
    By The Monk in forum Revit Architecture - General
    Last Post: 2011-08-12, 09:23 PM
  2. Rotated Titles for Rotated Views?
    By Kiteman48 in forum Revit Architecture - General
    Last Post: 2008-07-10, 05:55 PM
  3. Snap view crop regions, viewports, and view titles to reference planes/line in titleblocks
    Last Post: 2007-09-27, 02:15 PM
  4. How to Spell-check your Schedules, View titles, and Sheet Titles...
    By hand471037 in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-12-20, 09:11 PM
  5. Could View Titles be rotated with the View
    By tarch in forum Revit Architecture - General
    Last Post: 2004-07-13, 02:01 PM
