Results 1 to 10 of 14
Thread: Revit Performance - or Aaaaaaaagghhhrr!!! ( & Logitech)
    All AUGI, all the time Les Therrien's Avatar
    2003-05
    Tecumseh, Canada
    623
    Default
    What the..
    I am not sure if this is a hardware problem or a Revit one.
    When I hover my cursor over any walls it's like the walls are magnetic and the cursor is drawn to it! This therefore slows down the cursor until I pass the "magnetic field"?
    Yes I did get a new mouse along with many other upgrades. But the mouse/cursor does not do this in an of the 5.1 files.
    The mouse works fine elsewhere. It is a Logitech Mx 700 cordless optical.
    But i think this is Revit related since the problem does not exist anywhere else.
    Any ideas?????
    2001-12
    Irvine, CA
    7,567
    Default Re: Revit Performance - or Aaaaaaaagghhhrr!!! ( & Logitech)
    Les...I tweaked your subject...to make it easier to find in a search. I've never searched for aaaaargh...before but might now
    Anyway, your issue is the new to 6.0 performance setting available via Monitor settings, Settings tab Graphics Performance...setting it to NONE instead of FULL.
    Different operating systems have different info to follow but you may have received a prompt from Revit to change it by now?
    I could stop if I wanted to rhys's Avatar
    2003-05
    Cotswolds, UK
    433
    There was some discussion of this on the hardware forum.
    2003-05
    Tecumseh, Canada
    623
    Steve,
    Do you mean control panel > display settings > Hardware acceleration?
    Les
    2003-05
    Tecumseh, Canada
    623
    Thanks Steve.
    I tried that and it works!
    Happy Reviting!
    2003-04
    Chino, CA
    4,756
    yep, thats the one. turn hardware acceleration off, and the problem will go away.
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    Quote Originally Posted by Scott Davis
    With the ATI video cards around here, if hardware acceleration is set to either maximum or minimum values this behaviour does go away. (Intermediate values will cause that "magnetic" cursor behaviour you describe.) But having the acceleration off is terrible - it slows down your other programs.
    I've asked the Revit team what the deal is with the new video subsystem in Revit and haven't heard back yet. In the meantime get the latest video drivers and try full acceleration again.
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    2003-05
    Cotswolds, UK
    433
    There have been a number of posts in different forums about this do we think it is a bug or at least a "feature that needs documenting"?
    2003-05
    3,348
    Rhys, did the Logitech utility help you? Because that file is for configuring mouse speed and I would not have thought it related to the video problems people are having with R6.
  1. Revit and Logitech Mouse
    By greg002 in forum Hardware
    Last Post: 2018-09-23, 07:25 AM
  2. Logitech Performance MX Mouse
    By derek.96018 in forum Hardware
    Last Post: 2016-06-30, 09:02 PM
  3. Which Logitech mouse for Revit?
    By raymondjdawson925863 in forum Revit Architecture - General
    Last Post: 2015-04-27, 07:36 PM
  4. Logitech Performance MX and Revit
    By kangjl in forum Revit - Hardware & Operating Systems
    Last Post: 2010-09-06, 01:39 PM
  5. Logitech Performance MX and Revit
    By kangjl in forum Hardware
    Last Post: 2010-08-27, 04:12 PM
