Results 1 to 10 of 11
Thread: Properties Panel has died
    100 Club noozybkk's Avatar
    2005-05
    Bangkok, Thailand - (Currently working in Dubai)
    141
    Default Properties Panel has died
    My properties panel has carped out on me.
    When entities are selected, all that shows up in the properties panel is the entity count.
    Any pointers on how to get it back would be nice. See pic below.
    Also, my design centre has died also. When I try and pick a block or drawing in the design centre I get the following alert window -
    Error: The operation completed successfully.
    [C:\Program Files\AutoCAD 2004\acDcSymbols.arx]
    My first guess is that its a registry problem, but we all know that the registry is somewhere you don't wanna have to go - unless you reallllllly have to.
    Super Moderator rkmcswain's Avatar
    Earth
    9,696
    Default Re: Properties Panel has died
    Quote Originally Posted by noozybkk
    I would try to run a REPAIR on the install.
    Start -> Settings - Control Panel -> Add/Remove Programs -> Select the program, Repair.
    R.K. McSwain | CAD Panacea |
    2005-05
    141
    Quote Originally Posted by rkmcswain
    That's gotta be a last resort. I have never once had a successful repair that way and always wind up re-installing everything from scratch.
    13,654
    Hi
    Why?
    A repair install takes 5 minutes (approx) to perform... if that doesn't work, a complete uninstall / reinstall might be the order of the day... personally I would rather try the repair install first.
    Have a good one, Mike
    Midwest
    154
    Do you have support paths in your AutoCAD 2006 install that point to a previous release? This is my guess if you are having problems with DesignCenter in 2006 that is looking for 2004 files. I would try a reset possibly on the profile, otherwise I would give repairing the install a try.
    2005-05
    141
    Quote Originally Posted by Mike.Perry
    Hi
    Why?
    Ok, ok....Pass me a large slice of humble pie. The repair worked. I feel like an idiot....but in my defence I would say that my mistrust of automatic repairs is rooted in Microsoft products, not AutoDESK.
    2005-05
    141
    Quote Originally Posted by lee_ambrosius
    Dunno how it managed to run off and come up with the 2k4 path. Has me stumped also - I checked all the paths in all the profiles (Mech & MDT also) and there was nothing pointing to the old 2k4 location.
    Anyway, I'm good to go again and all my customisations survived the repair...and all before the home time bell...yippee - I am now off to a wine tasting to get sozzled.
    13,654
    Thumbs up Re: Properties Panel has died
    Hi
    There is no reason to feel like that...
    Good to hear it worked, and you are up and running again.
    2003-03
    North Tonawanda, NY
    13
    Thanks for this post.
    My properties window also has become a void.
    I am off to run a repair as well.
    Sincerely,
    Ray Chotkowski
    Designer - Vishay Thin Film
    I could stop if I wanted to jgratton's Avatar
    2002-07
    Calgary, Canada
    397
    I am running 2006 on winxp and these instructions confused me. After selecting Acad 2006, I have to select the change button. Then the repair option becomes available.
  1. 2011: Panel properties settings
    By PanzerRanger in forum AMEP General
    Last Post: 2014-04-02, 05:24 AM
  2. Properties Box in the Tab Panel
    By nealehiggs in forum ACA General
    Last Post: 2012-10-24, 11:26 AM
  3. Properties Box in the Tab Panel
    By nealehiggs in forum ACA/AMEP Tips & Tricks
    Last Post: 2012-10-22, 11:29 PM
  4. quick properties panel
    By rmk in forum AutoCAD General
    Last Post: 2011-05-16, 01:44 PM
