Thread: Thickened Slab (turned down slab)
    Lynchburg, VA
    27
    Question Thickened Slab (turned down slab)
    I am still trying to learn ADT 2006. What is the best method for making a floor slab be thicker around the edges. In civil we called it a turned down slab. One of our architects calls it a thickened slab. Po-tay-toes Po-Tah-Toes. I just need to know how to make one in ADT 2006. If someone could point me in the right direction I would really appreciate it.
    Jackie Bliss
    CAD Manager
    Wiley|Wilson
    2002-09
    Madison, WI
    5,674
    Default Re: Thickened Slab (turned down slab)
    There is an out o the box slab edge style called haunch (I think).
    I'm pretty sure this is what you are looking.
    Lynchburg, VA
    27
    Thanks a lot David. You are right the name of the edge style is "Haunch". Once you gave me the name I found it in the slab styles drawing.
    Jackie Bliss
    CAD Manager
    Wiley|Wilson
    2002-09
    Madison, WI
    5,674
    If you need to make look different, just copy and modify the edge style.
  1. Chamfer Thickened Slab
    By bpierce290463 in forum Revit Structure - General
    Last Post: 2012-01-29, 12:16 AM
  2. Thickened Slab Footings?????
    By tknapp in forum Revit Structure - General
    Last Post: 2011-09-27, 05:08 PM
  3. 2 Thickened Slab Edges in ONE Foundation Slab
    By TurboAdy in forum Revit Structure - General
    Last Post: 2011-05-24, 09:29 PM
  4. Thickened Slab
    By ruth.rogers48502 in forum Revit Structure - Families
    Last Post: 2010-09-24, 01:34 PM
  5. slab-on-grade with gravel and thickened slab edge joining
    By t1.shep in forum Revit Architecture - General
    Last Post: 2009-11-23, 04:04 PM
