This has been discussed before, but I'd like to start the thread again.
Could we have the factory add a New/Existing parameter to the Revit-supplied Door families?
I'm about to embark on duplicating the Door families & drawing the leaf at 45 degrees instead of 90. I believe this is pretty much an industry standard, so it would be nice to be able to just change a parameter on a bunch of doors at once instead of having to load twice as many families and then swapping out all the 36" doors, then all the 42" door, then all the 48" doors.
As an alternative, rather than having a New/Existing check box, how about a parameter for Opening Angle? The default would be 90, but you could set the Angle to 45 (or 30, or 60) for Existing. That might take care of the 3D display showing closed doors, too.
Does this warrant a Poll?
