Results 1 to 10 of 11
Thread: Remote access from work to home
    AUGI Addict madcadder's Avatar
    Broken Arrow, OK
    1,005
    Default Remote access from work to home
    I installed a firewall and networked the computers at home a few weekends back.
    Is there an EASY way to access my hard drive at home if i know the IP?
    2001-05
    Austin, TX USA
    2,201
    Default Re: Remote access from work to home
    Using a program like pcAnywhere would do what you want.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    Broken Arrow, OK
    1,005
    Quote Originally Posted by gpope
    I thought about checking into something like that, but figured it had to be easier than spending money.
    Broken Arrow, OK
    1,005
    Does VPN work with Win2k?
    100 Club rclayton's Avatar
    2005-04
    Harrisville, MI
    166
    Quote Originally Posted by todw
    VPN does work with Win2K, but you will need a VPN Server to connect to. This can be done with a router that has a VPN Server built-in or by installing Win2K Server and enabling Routing and Remote Access.
    Win2K Workstation does not have the capability of acting as a VPN Server built-in so either way you will need to spend some money to get what you want.
    pcAnywhere is probably your cheapest and easiest solution overall unless you already have a copy of Win2K Server
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    You might be able to use Remote Desktop, or Terminal Services as it's known in Win 2K. If my memory is right, it's not installed with Win 2k but you can download it from Microsoft's website for free.
    I've not set it up myself, but from talking to those who have, you do have to open up some ports on the home machine to allow the connection.
    The other issue (and it's a potential big one), it' s not as secure as a VPN or some of the other methods of remotely answering a system.
    I hope this helps.
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
    2001-05
    Austin, TX USA
    2,201
    Another option would be to set up an FTP server on your home computer. There are some free ones out there. I had used one for a while, but forgot the name. Also there are some free remote access tools. Don't known how well they work. Haven't tried any of them.
    list of free remote access programs
    Open source FTP server/client: FileZilla
    Golden FTP Server Free
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    Broken Arrow, OK
    1,005
    Quote Originally Posted by rclayton
    VPN does work with Win2K, but you will need a VPN Server to connect to. This can be done with a router that has a VPN Server built-ir
    I'm using a Netgear rp614v2(?) that does have VPN built into it. (won't do wireless)
    Outside the help files from Netgear <smirk> where's a trusted site to read-up on what i will need to do?
    I'll check into FTP also. Thanks.
    2001-05
    Austin, TX USA
    2,201
    Don't know if you already have something in place, but this might interest you. I just started using this and it was extremely easy. Just install the software on any computer you want to connected to your VPN network. Works through most routers with no changes to setting. Like I said extremely easy.
    http://www.hamachi.cc/
    Quote Originally Posted by from Hamachi web site
    With Hamachi you can organize two or more computers with an Internet connection into their own virtual network for direct secure communication.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    I could stop if I wanted to lmitsou's Avatar
    2003-01
    UK
    219
    Have you tried using VNC to connect remotely to your PC? It is a very cheap and easy solution.
    L. Mitsou
  1. 2012: Work Remote Via VPN on my laptop
    By gfreddog in forum AutoCAD General
    Last Post: 2012-04-24, 12:17 AM
  2. 2012: worksharing for remote work
    By tyson952068 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2012-03-16, 08:06 AM
  3. Remote access question
    By peakprecisiondesign in forum Revit Architecture - General
    Last Post: 2009-06-25, 05:33 PM
  4. Outlook Remote Access
    By mmiles in forum Revit - Hardware & Operating Systems
    Last Post: 2008-12-12, 04:07 PM
  5. Design File Remote Access (Buzzsaw, Newforma, ProjectWise)
    By andybosch in forum CAD Management - General
    Last Post: 2008-02-19, 07:01 PM
