Results 1 to 8 of 8
Thread: Open Template file from a Network location
    2015-11
    Cardiff, Wales, UK
    50
    Default Open Template file from a Network location
    Hello All,
    I am creating a custom command that will open a specific template file ("dwt") located on a network folder.
    The problem is that instead of opening that file, Autocad prompt for the file name and @ that point if I hit enter, it opens the file.
    Can anybody help me eliminate that prompt.
    Also I am not sure if the filedia variable that I am trying to reverse @ the end of the macro will work.
    Any ideas.
    Below is the macro I am trying to use.
    ^C^C_filedia 0 new I:\library\templates\misc\1.dwt filedia 1^C^C_
    I appreciate any ideas.
    Thank you all.
    Jaime Silva
    13,657
    Question Re: Open Template file from a Network location
    Hi
    Could you not just use the _.QNew command?
    Have a good one, Mike
    2015-11
    Cardiff, Wales, UK
    50
    Default Re: Open Template file from a Network location
    Quote Originally Posted by Mike.Perry
    Hi
    Hi Mike,
    This is the way we do, but I was trying to eliminate the steps of searching the many network folders we have with different template files.
    Thanks.
    Jaime
    13,657
    Quote Originally Posted by drafting.82475
    Hi
    Sorry you have lost me here a little...
    _.QNew does not require searching of "many network folders".
    Options -> Files tab --> Template Settings -> Default Template File Name for QNEW
    2015-11
    Cardiff, Wales, UK
    50
    Hi
    Hi Mike,
    I have inside my template folder on the network, 7 different folders w/ template files. What I am trying to accomplish is, under my workspace "Details", create a toolbar where I can open template files ( 6 different detail templates ) from one of the seven folders on the network with a click of a button (1 button for each different template - total 6 buttons).
    When I use the QNew, I can only open one of the 6 files I have inside that specific folder.
    The reason behind this is that we draw a large amount of details here, if I can get this done, I will be reducing about 120 mouse clicks on a daily basis.
    Thank you.
    Jaime
    13,657
    Hi
    Ok! how about setting up "X" number of AutoCAD desktop icons and using the /t command line switch...
    ID: TS17888 - Start with specific drawing template
    ID: TS24235 - Defining a default drawing template file
    ID: TS22957 - Startup switches
  1. Sheet Set Template File Location in c#
    By oakam430373 in forum RealDWG
    Last Post: 2017-09-04, 01:47 AM
  2. Replies: 5
    Last Post: 2010-06-04, 06:45 PM
  3. Template file location
    By gadjet in forum CAD Standards
    Last Post: 2009-12-04, 07:50 PM
  4. Replies: 4
    Last Post: 2007-01-22, 11:04 AM
