Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: From acad (only acad) File\Open I am unable to access my C: drive
    0,0,0 The Origin
    8,570
    Default From acad (only acad) File\Open I am unable to access my C: drive
    I've built a new standalone pc, installed XPpro and A2006.
    From acad (only acad) File\Open I cannot access my C: drive. The error message is -
    \\P2-350\SharedDocs is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
    The network path was not found.
    \\P2-350\ does not appear in the acad files lists and it does not appear in the registry.
    P2-350 was the name of my old pc. The only common part is the primary hard drive from the old pc that is a secondary drive on the new one.
    Any thoughts?
    2000-01
    Seattle WA USA
    5,859
    Default Re: From acad (only acad) File\Open I am unable to access my C: drive
    Turn RememberFolders off momentarily?
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Did you change the jump(s) on the old drive to be a slave drive instead of the master?
    I've seen this when both the drive were set to "cable-select"..
    0,0,0 The Origin
    8,570
    Quote Originally Posted by RobertB
    Thanks Robert. I'll try that when I get back home.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by todw
    Thank Tod. Yes I did.
    0,0,0 The Origin
    8,570
    No. That didn't work even after rebooting.
    2000-01
    Seattle WA USA
    5,859
    Might that path be located in a shortcut on the left pane of the dialog box?
    0,0,0 The Origin
    8,570
    Do you mean Favourites, History, Buzzsaw, etc.?
    If so, no, it's not there either.
    I hate to admit this but I think I'm going to have to reinstall - the last resort.
    0,0,0 The Origin
    8,570
    A complete acad uninstall/install didn't fix it either so I'm going to have to get seriously mean with this pc later in the week.
    100 Club RobertAitken's Avatar
    2000-10
    Sunny Scotland
    148
    Quote Originally Posted by johnbogie
    Did you install the OS on a new HD or move the existing disk? If a new disk disconnect the old disk and boot from there.
    Robert
  1. Replies: 2
    Last Post: 2014-10-17, 04:57 PM
  2. 2005: Object Enabler to open file in Acad 2005?
    By Marie789 in forum AutoCAD General
    Last Post: 2014-03-27, 05:14 PM
  3. Open PDF file from ACAD
    By mvsawyer in forum AutoCAD General
    Last Post: 2010-11-16, 09:56 PM
  4. Access Excel from ACAD
    By csorensen in forum CAD Management - General
    Last Post: 2010-02-12, 07:22 PM
  5. Replies: 3
    Last Post: 2006-06-05, 10:45 PM
