Thread: DWG and Image have different Coordinate Systems, what to do?
    2005-05
    12
    Default DWG and Image have different Coordinate Systems, what to do?
    I have survey data in a DWG in State Plane and I have an image in UTM.
    I want to have the image behind my survey data.
    I have read a few posts on attaching and querying, but I am not fully clear on it. Been spending some time trying to figure it out, and it's not working out.
    My concern is I don't know any common points that the 2 have. I wasn't in the field collecting this information, and the people that were want to see how this data looks over an image.
    Any one have any suggestions?
    Thanks
    Dennis
    2001-05
    Austin, TX USA
    2,201
    Default Re: DWG and Image have different Coordinate Systems, what to do?
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2005-05
    12
    Not that one, but seen a few that descibe things like it.
    I guess my guestion is when you say "run query".....I am confused.
    What is the query I need to enter?
    2001-05
    Austin, TX USA
    2,201
    You could just do a simple location all query. This will pull in everything from each attached drawing.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
  1. 2012: Changing Coordinate Systems
    By bap020799 in forum AutoCAD General
    Last Post: 2012-07-23, 07:46 PM
  2. How to set zero coordinate systems
    By dmurphy508490 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-06-01, 06:29 PM
  3. Change coordinate systems on the fly
    By jessebelcher in forum AutoCAD Map 3D - Wish List
    Last Post: 2010-02-09, 09:13 PM
  4. Multiple coordinate systems
    By benmay in forum Revit Structure - General
    Last Post: 2010-02-01, 08:56 PM
  5. Set up two coordinate systems in same drawing
    By A Myth in forum AutoCAD General
    Last Post: 2007-02-17, 09:59 PM
