Thread: VBA Fails to Initialize, ACAD 2004
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,611
    Unhappy VBA Fails to Initialize, ACAD 2004
    Revit user here, needing to reinstall AutoCAD for a few drawings.
    I just upgraded 2 machines from win2K to XP. Identical machine specs. Reinstalled Autocad on both machines. One runs fine, the other crashes every time I try to load VBA apps. Typing VBALOAD, VBAMAN, VBAIDE, etc. all crash AutoCAD. I've reinstalled AutoCAD and added VB to see if that would help. Basically this machine is clean of other software (except clean installs of Office, Symantec, Revit, and a few other standard apps) so I'm at a loss about what the problem could be.
    Andre
    Turlock, CA
    5,680
    Default Re: VBA Fails to Initialize, ACAD 2004
    Do you have any dvb's loading? One of them could be corrupted.
    C:> ED WORKING....
    2003-12
    Point of no return
    1,611
    um, thanks... what's a dvb?
    2001-11
    Manchester, UK
    47
    Just a suggestion - but
    I had this on one of our PC's. Turned out that during installation the vba bit wasn't installed from the options. Reinstallation checking the vba option cured the fault. If you have it installed something may be corrupt or missing.
    Turlock, CA
    5,680
    A dvb is the file extension for acad compiled vba projects. If they get corrupted or are compiled for a different version of acad, they won't load.
    C:> ED WORKING....
  1. Simple Action fails in Acad 2009
    By tavo in forum AutoCAD Action Recorder
    Last Post: 2009-01-19, 10:27 PM
  2. ACAD 2007 saving down to ACAD 2004 - ARX Error: eDuplicateKey
    By Dicastaddict1 in forum AutoCAD General
    Last Post: 2006-10-26, 03:35 PM
  3. Need to covert 1992 Acad dwgs to present 2004/5 Acad!
    By anapier in forum CAD Management - General
    Last Post: 2005-02-17, 05:51 AM
  4. ACAD 2004 OLE OBJECTS
    By ricodominguez in forum AutoCAD General
    Last Post: 2004-12-22, 09:30 AM
  5. License mgr. ACAD 2004 & XP Pro.
    By reed.76512 in forum Networks
    Last Post: 2004-10-06, 09:11 PM
