Thread: "ADT as AutoCAD 2006" or "Autodesk Architectural Desktop 2006"
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default "ADT as AutoCAD 2006" or "Autodesk Architectural Desktop 2006"
    Sometimes *) when I start "ADT as AutoCAD 2006" this occurs
    Loading AEC Base...
    Loading AEC Base UI...
    *) = when I double click in Explorer, not when I start from the desktop icon.
    I want to programmatically identify if the task is started as
    or as
    I use (member "aecmodeler47.dbx" (arx)) to identify
    but it fails if AEC Base has been loaded in both tasks.
    Is there a better and secure way to find the difference ?
    (I do not want to identify the tasks by toolbars or menu files items )
    : ) Happy Computing !
    kennet
    2000-01
    Seattle WA USA
    5,859
    Default Re: "ADT as AutoCAD 2006" or "Autodesk Architectural Desktop 2006"
    I'm not sure it is going to matter. Why?
    If a drawing file has ADT objects in it (even just the dictionaries, and no visible objects) the embedded object enabler is going to load the ADT support files, regardless of what profile is used for starting AutoCAD. So if you open a file from Explorer, or AutoCAD's Open dialog, even if you used the "ADT as AutoCAD 2006" shortcut last, you are going to get ADT if the drawing you selected has ADT objects.
    2002-05
    1,707
    Thanks Robert.
    I have recognized that different combinations of arx files are loaded depending on how the task is started, but it is not 100% secure.
    (cond
      ((and (not (member "acmgdinternal.dll" (arx) )) (not (member "aecstartup47.arx" (arx) ))) (princ "AutoCAD 2006 started from DT Icon" )(princ) )
      ((member "acmgdinternal.dll" (arx) ) (princ "AutoCAD 2006 started from Explorer" )(princ) )
      ((and (member "aecstartup47.arx" (arx) ) (not (member "units.arx" (arx) ))) (princ "ADT 2006 started from DT Icon" )(princ) )
      ((member "units.arx" (arx) ) (princ "ADT 2006 started from Explorer" )(princ) )
      (t nil)
    I have to investigate further....
    kennet
  1. Replies: 0
  2. Replies: 3
    Last Post: 2007-10-30, 07:29 PM
  3. AutoCAD LT 2006 - add "IF" logic to Floating Viewport macros
    By Paul Munford in forum AutoCAD LT - General
    Last Post: 2007-04-04, 07:06 AM
  4. AutoCAD 2006 - Missing all the buttons on "Dimension" toolbar
    By jonathanschade in forum AutoCAD CUI Menus
    Last Post: 2007-03-23, 11:57 PM
  5. Replies: 13
    Last Post: 2006-05-25, 09:32 PM
