Results 1 to 7 of 7
Thread: Unchanged dwg still prompts to save changes
    100 Club jsr13's Avatar
    Virginia - USA
    134
    Default Unchanged dwg still prompts to save changes
    We've got Arch Desktop 2004 (using as AutoCAD only - no Desktop amenities). Many times we will open a dwg file just to view or plot. Every time we close those drawings, we are prompted to "save changes." I have tested this out: open a drawing & close that drawing with nothing in between. No zooms, pans... Nothing in between OPEN & CLOSE, yet we are still prompted to "save changes."
    Is there a way to change this? If you make no changes, it shouldn't prompt you to save something you didn't do, right? It's a small thing, but something that really shouldn't happen. Right?
    Thanks in advance for any input & help.
    I could stop if I wanted to scwegner's Avatar
    2004-12
    Minneapolis, MN
    449
    Default Re: Unchanged dwg still prompts to save changes
    It happens because AutoCAD considers lots of things a drawing change. If it's happening when all you do is open and then close, then I would guess that you have a lisp or something that runs at startup that's registering as a change. You can get a better idea of what's happening by checking the dbmod system variable.
    1 Object database modified
    4 Database variable modified
    8 Window modified
    16 View modified
    32 Field modified
    You can suppress it with vlisp using acdbSetDbmod( ) but that can be dangerous because if you don't do it correctly it may not prompt when there really was a change you wanted to save.
    Another way is to use acad-push-dbmod and acad-pop-dbmod with the same risk.
    0,0,0 The Origin
    8,570
    If you open a second file that is seen as a change to the first file.
    13,656
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS42354 - Save changes prompt displays when no changes to drawing were made
    Have a good one, Mike
    Virginia - USA
    134
    Quote Originally Posted by scwegner
    Well, I'll not worry about it since it's such a trivial thing when there is the possibility of it not prompting when it should.
    Thanks for the info anyway, guys!
    Is there any example on how to do that with vlisp?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by Michael.Zindath773861 View Post
    Check out: http://help.autodesk.com/view/ACD/20...0-FFEA28E5A86F
    and: http://docs.autodesk.com/ACD/2011/EN...b7ccc-6ad4.htm
    for ideas to put in to your acaddoc.lsp file
    (setvar 'dbmod 0)
  1. API Control of Prompts
    Last Post: 2014-05-15, 11:57 AM
  2. Replies: 0
    Last Post: 2011-10-24, 03:45 PM
  3. Block prompts
    By gfreddog in forum AutoCAD General
    Last Post: 2009-05-26, 04:40 PM
  4. Defaults in prompts?
    By g_wong in forum AutoLISP
    Last Post: 2009-01-30, 04:53 PM
  5. Keywords in prompts for Block Attribute Prompts.
    Last Post: 2009-01-13, 04:21 PM
