Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Match text strings by selecting
    2003-10
    Las Vegas
    22
    Exclamation Match text strings by selecting
    Does anyone know where I can find the lisp routine that when I pick a text string (example: Install blah blah) then I pick another text string and it will make the second text string match the first string word for word ?
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: Match text strings by selecting
    You can try this code :
    (defun c:InfectText (/ Ent TextSource SelSet Items Index EntDxf )
      (command "_.UNDO" "BEgin" )
      (if (setq Ent (entsel "Select the text infection source : " ) )
        (progn
          (if (= (cdr (assoc 0 (entget (car Ent ))) ) "TEXT" )
            (progn
              (setq TextSource (cdr (assoc 1 (entget (car Ent )))) )
              (prompt "\nSelect text to infect : " )
              (if (setq SelSet (ssget '((0 . "TEXT" ))) )
                (progn
                  (setq Items (sslength SelSet ) )
                  (setq Index -1 )
                  (repeat Items
                    (setq Index (1+ Index ) )
                    (setq EntDxf (entget (ssname SelSet Index ) ) )
                    (setq EntDxf (subst (cons 1 TextSource ) (assoc 1 EntDxf ) EntDxf ) )
                    (entmod EntDxf )
                  (princ (strcat (itoa Items ) " text objects changed to " TextSource " ! " ) )
                (princ "No text selected ! " )
            (princ ".... you must select TEXT ! ")
        (princ "Miss, aim better ! ")
      (command "_.UNDO" "End" )
      (princ )
    : ) Happy Computing !
    kennet
    I could stop if I wanted to LanceMcHatton's Avatar
    2002-04
    Las Vegas, NV, USA
    304
    Kennet,
    Did you write that code? I think I'll be replacing mine with yours and I'd like to give credit where it's due.
    2002-04
    Las Vegas, NV, USA
    304
    Here's one that we use. It also only works on DTEXT entities but it's only good for a single use, whereas Kennet's lisp will pick a source and apply it to all selected entities.
    ;  Description: Function to replace the value of a text entity with the
    ;  value of another text entity.
    ;  Originally written By: Robert P. Ehrman - 1/19/91
    ;  Modified by Lance McHatton for GCWallace, Inc. - March 24, 2004
    ;  Operation: The routine will ask you to pick two lines of text, then it
    ;			 will change the values of the second entity, but will not modify
    ;			 it in any other way, for instance, see below:
    ;			 Before the routine:
    ;			   text entity 1 is "L500" at 1,1 on "TH" with a value of "BACK OF CURB"
    ;			   text entity 2 is "L100" at 9,9 on "TS" with a value of "2900.25"
    ;			 After the routine:
    ;			   text entity 2 is "L100" at 9,9 on "TS" with a value of "BACK OF CURB"
    ;  Note: This lisp will only work on DTEXT entities.
    (defun C:GCWCOPYTEXT (/ End Cmde Olderr Ename1 Ename2 Elist1 Elist2 Text1 Text2)
      (defun End (s)
    	(setvar "CMDECHO" Cmde)
    	(princ s)
    	(setq *error* olderr)
    	(princ)
      (setq Cmde	 (getvar "CMDECHO")
    		Olderr   *error*
    		*error*  End)
      (while 1
    	(setq Elist1 '((0 . "BOGUS")))
    	(while (not (= (cdr (assoc 0 Elist1)) "TEXT"))
    	  (setq Ename1 (car (entsel "\nSelect FIRST text string. : ")))
    	  (setq Elist1 (entget Ename1)))
    	(setq Elist2 '((0 . "BOGUS")))
    	(while (not (= (cdr (assoc 0 Elist2)) "TEXT"))
    	  (setq Ename2 (car (entsel "\nSelect SECOND text string. : ")))
    	  (setq Elist2 (entget Ename2)))
    	(setq Text1 (cdr (assoc 1 Elist1)))
    	(setq Text2 (cdr (assoc 1 Elist2)))
    	(setq Elist1 (subst (cons 1 Text2) (assoc 1 Elist1) Elist1))
    	(setq Elist2 (subst (cons 1 Text1) (assoc 1 Elist2) Elist2))
    	(entmod Elist2)
      (End "\nFunction completed.")
      (princ)
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Here is another one to consider.
    ; Original Program Name: C:CA
    ; Description:  Match text values in attributes or text strings. Pick
    ;               Source entity (Attribute or Text) then pick destination
    ;               entity, it will copy the text value from the source to
    ;               the destination.
    ; Date:         4-23-99
    ; Version:      1.00
    ; Author:       Micah Nerren (714) 556-4454
    ; New Program Name: C:CopyText
    ; Overhauled 06-19-02 by John Uhden, Cadlantic
    ;       based on request by jducharme@reid-crowther.com
    ;       in the AutoCAD Customization Newsgroup.
    ; Note: Since there's almost nothing left of the original code,
    ;       this is donated as public domain, aka "Freeware"
    ;       R15+ only
    (defun C:CopyText ( / *error* source text pick target ent layer)
      (vl-load-com)
      (if (not *acad*)(setq *acad* (vlax-get-acad-object)))
      (defun *error* (errmsg)
        (vla-EndUndoMark (vla-get-activedocument *acad*))
        (and
          errmsg
          (not (wcmatch (strcase errmsg) "*QUIT*,*CANCEL*"))
          (princ (strcat "\nERROR: " errmsg))
        (princ)
      (vla-StartUndoMark (vla-get-activedocument *acad*))
      (AND
        (setq source (car (nentsel"\nSelect Source Text/Attribute: ")))
        (setvar "errno" 0)
        (or
          (member (cdr (assoc 0 (setq source (entget source))))'("TEXT" "ATTRIB"))
          (prompt "\n  Must be either an Attribute or Text!")
        (setq text (cdr (assoc 1 source)))
        (princ (strcat "\n  Source Value = " text))
        (while (/= (getvar "errno") 52)
          (and
            (setq pick (nentsel "\nSelect target Text/Attribute to change: "))
            (setq target (car pick))
            (setq ent    (entget target)
                  layer  (cdr (assoc 8 ent))
                  target (vlax-ename->vla-object target)
            (or
              (= (length pick) 2)
              (prompt "\n  Target is nested in a Block or Xref")
            (or
              (member (cdr (assoc 0 ent)) '("TEXT" "ATTRIB"))
            (or
              (/= (logand 4 (cdr (assoc 70 (tblsearch "layer" layer)))) 4)
              (prompt (strcat "\n  Layer " layer " is locked"))
            (or
              (/= (vla-get-textstring target) text)
              (prompt "\n  Text is the same.")
            (and
              (not (vla-put-textstring target text))
              (princ "\n  Failed to modify target.")
      (*error* nil)
    2002-05
    1,707
    Quote Originally Posted by LMcHatton
    Kennet, Did you write that code?
    Yes ! Do whatever you like.
    kennet
    2002-04
    Las Vegas, NV, USA
    304
    Quote Originally Posted by ab2draft
    Ok, now THAT one rocks! It does DTEXT and ATTRIBUTES! Back and forth!
    I wish all my favorite lisps would work out this way...getting better and better with every new post.
    2003-10
    Las Vegas
    22
    Hey Thanks everyone. This is just what I was looking for.
    2015-09
    420
    Hello To Everyone:
    Kennet, could your routine be modified to work with both "Text" and "Mtext" strings....???
    It would be very helpful if it could be accomplished....!!!
    Thank you for any assistance.
    2002-05
    1,707
    Quote Originally Posted by vferrara
    Hello To Everyone:
    Change the line
    to
    (if (setq SelSet (ssget '((0 . "TEXT,MTEXT" ))) )
    But it will NOT work at all MTEXT
    kennet
  1. Replies: 4
    Last Post: 2014-03-02, 01:06 AM
  2. Linking text strings
    By DaleSmith in forum Revit Architecture - General
    Last Post: 2011-11-25, 09:26 AM
  3. Text strings in Dimensions
    By DaveP in forum Revit Architecture - Wish List
    Last Post: 2006-06-26, 12:34 AM
  4. Match Text string by selecting
    By lapace in forum AutoCAD General
    Last Post: 2005-10-18, 03:34 PM
  5. formating text strings
    By rwbaker in forum VBA/COM Interop
    Last Post: 2005-09-20, 06:02 PM
