Thread: Sheet Set Custom Properties
    2005-02
    54
    Default Sheet Set Custom Properties
    After setting up the custom properties. How do I link them to my Fields? I'm inserting fields in my attributes in my companies title block.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Sheet Set Custom Properties
    Have you looked at this thread?
    How do I get fields working with SSM?
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2005-02
    54
    Question Re: Sheet Set Custom Properties
    I have nothing under "Custom Property Name" to select. I did set up custom property names.
    I did everything to the thread you referred me to. But I don't see my custom property names or the defaults... I only see things went I use the Civil or Arch dwt. But that has a default title block.
    2005-02
    54
    Cool Re: Sheet Set Custom Properties
    OK, did some magic and was able to see my Custom Property Name.
  1. Sheet set / Sheet custom properties data validation
    By tawfik72 in forum CAD Management - General
    Last Post: 2010-11-22, 11:54 AM
  2. Custom sheet properties
    By Bryan Thatcher in forum ACA General
    Last Post: 2009-03-13, 06:56 PM
  3. Replies: 5
    Last Post: 2009-02-23, 09:12 PM
  4. Sheet set custom properties
    By feargt in forum VBA/COM Interop
    Last Post: 2009-02-16, 11:34 PM
  5. Sheet Manage Custom Properties
    Last Post: 2007-09-27, 06:06 PM
