I have a user who "discovered" a routine for drawing welding symbols that was buried in the Detailing section of the Sample Palette Catalog - Imperial tool catalog in the Content Browser (whew, that was a long one). He placed the tool for this routine on a palette and started using it, but with some mysterious results. The routine brings up a seemingly comprehensive dialog box that will insert the weld symbol(s) of choice along with some descriptive text and dimensions if needed. The text shows up as attributes in a block, but the inserted text is not matching the text entered in the routine's dialog box.
If he enters "3/16" as the dimension for the weld he gets a "~3". There is no help section for this command (the command is "AecDetailsWelding"), and Google doesn't even return any results. Has anyone ever used this routine, and does anyone know what variables might be affecting these results?
Thanks.
James Snyder
