Results 1 to 1 of 1
Thread: How to Quote Others
    2001-12
    Irvine, CA
    7,515
    Default RE: Multiple quotes in a reply
    To quote someone like this: (assuming you need to quote more than just the post you are replying to or want to quote several lines.
    Quote Originally Posted by Vizzini
    Inconceivable!!
    Quote Originally Posted by George Washington
    I can not tell a lie!
    First check out THIS TIP to set up the enhanced editor.
    If you do you can use a little button to add quote codes and then paste text in between. To give credit to the other person you just need to add the =username after the first quote. I've attached a couple images to help...hopefully.
