Thread: Append to sdr file?
    Member jbbarrus's Avatar
    2005-07
    Utah
    34
    Default Append to sdr file?
    Is there any way to download a working sdr file, add new points to it and then reload it onto the data collector? I am using Carlson Connect with a Sokkia SDR 33 data collector. This would be a tremendous help. I currently have to load a new job or key the points in manually. We do have Autodesk Survey in the office also, but not at my workstation.
    John Barrus
    2004-05
    8
    Default Re: Append to sdr file?
    I've never tried to append an existing file on an data collector. If I download a survey and add points in the drawing I create a point file and upload the point data into the data collector. I create an Autodesk up-loadable file .auf. The format of the file needs to be PNEZD and comma separated.
    Member jhoubart's Avatar
    2007-03
    Belgium - Liège
    5
    I use HJ SdrCodeFbk. The first module of this program convert SDR file to FBK witch parsing code and the second module convert AUF file to SDR.
  1. Append timestamp ?
    By kathey1 in forum Revit Architecture - General
    Last Post: 2017-10-24, 10:28 AM
  2. Append Vectorworks Files
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2014-11-06, 02:24 PM
  3. Append xdata?
    By d_m_hopper in forum AutoLISP
    Last Post: 2009-07-02, 01:35 AM
  4. Merge vs. Append
    By eric.fox in forum NavisWorks - General
    Last Post: 2009-03-16, 05:11 PM
  5. "Cannot append to plot stamp log file" ?
    By alexmirb in forum AutoCAD Plotting
    Last Post: 2007-01-26, 01:03 AM
