Results 1 to 10 of 11
Thread: Sheet Count In Sheet Manager. Anyone?
    2001-11
    236
    Thumbs down Sheet Count In Sheet Manager. Anyone?
    What's up with Autodesk with not adding an option in SSM to count the total or sub-total number of sheets in a plan set; or maybe I missed where to find it in 2005? There is a "SheetCount.dvb" routine out there to automatically count the number of sheets in a plan set. This routine works but I am in the testing phase to be sure it is compatible with AutoCAD in all aspects.
    Or does anyone have an Autodesk's solution?
    All AUGI, all the time SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    500
    Default Re: Sheet Count In Sheet Manager. Anyone?
    I had the same problem. I ended up just making a Custom Field for the sheet set titled "Total Sheet". When I know how many sheets there will be, I just fill in the number manually.
    What I want also is a system variable that you could turn on or off to automatically renumber the sheets as you drag and drop them when they change order or add/delete a sheet. You shouldn't have to renumber them yourself!
    2008-10
    Hi. I was wondering if you'd found a solution to numbering sheets.
    2001-11
    236
    Quote Originally Posted by indianateresa View Post
    It's been a while now. I don't work were I started searching for answers on sheet count.
    However, then, I found something that might interest you. See attached.
    2008-10
    Thanks for the guidance. I used the sheetset custom field and it works just how I need it to.
    You all make my job SOOOO much easier! Thanks again!
    Teresa
    2015-09
    420
    Omorah,
    Thank you for the information.
    I used the SheetCount.dvb routine and it counted the total number of sheets in the sheet set perfectly.....Is there a way to get the number of an individual sheet within the set, such as Sheet 2 of 30....??
    Any help would be appreciated...!
    Regards,
    Vince
    2001-11
    236
    Sorry. I wish I have the information. I have not searched for such routine, maybe someone has made one up. If I come accross any, I will "try" to post it.
    2010-02
    Question Re: Sheet Count In Sheet Manager. Anyone?
    How does one incorporate the dvb file into the program?
    2010-07
    25
    We have the "Total Number of Sheets" as a property in the SSM. Because we label our sheets 1, 2, 3, etc. it's pretty easy to count, but I can understand the difficulty if you name your sheets differently.
    You can insert an attribute that is linked to the current sheet page number (see attached).
    Basically, you would have this: "Current Sheet Page Number Field" of "Current Sheet Set Custom Total Number of Pages" in your Titleblock.
    I hope that's clear?
    SSMPropEditor might also help.
  1. Replies: 1
    Last Post: 2014-11-20, 12:27 AM
  2. Replies: 0
    Last Post: 2014-02-28, 07:32 AM
  3. Check box to have newly created sheet set open in sheet set manager
    Last Post: 2012-01-25, 04:07 PM
  4. Create Sheet Lists and Total Sheet Count for Subsets in Sheet Set Manager
    Last Post: 2008-10-12, 06:30 PM
  5. AutoCAD 2008 - Sheet Set Manager no longer opens sheet sets
    By sjz in forum AutoCAD Sheet Set Manager
    Last Post: 2007-08-23, 03:09 PM
