Thread: Using BURST instead of EXPLODE
    2005-05
    55
    Default Using BURST instead of EXPLODE
    It doesn't retain the ploylines if you alter the scale of the block before you "Burst" it. It seems to work fine if you insert the block to scale. So if you have any other suggestions... I'm open.
    Thanks anyway,
    Ryan
    2001-12
    St. Louis
    5,347
    Talking Re: Using BURST instead of EXPLODE
    Quote Originally Posted by ryan.87191
    Thanks anyway,
    Ryan
    Ryan, I am going to move this from the tips and tricks forum as I think your question will be better served here. Thanks.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use BricsCAD, Revit, & Tririga, too)
    Technical Editor
    2004-08
    Hartford, Michigan
    3,197
    Default Re: Using BURST instead of EXPLODE
    Burst will retain the poly lines if you do not use decimal scales. for example, if you type in .2 in the x,y,and z scale boxes, it thinks that it is a non-uniformly scaled block, and therefore reacts in that way, however if you type in 1/50 in all the boxes, even though it displays .2, AutoCAD will treat it as a uniformly scaled block. I had that issue using CHSPACE with blocks from model space to paper space, the blocks were scaled down at the scale of the viewport, but AutoCAD still treated them as nonuniform
  1. Convert Explode command to Burst command?
    By stusic in forum AutoLISP
    Last Post: 2013-06-18, 11:55 PM
  2. 2008: Possible to Explode/Burst Blocks and Maintain Xclips?
    By ReachAndre in forum AutoCAD General
    Last Post: 2011-11-09, 01:01 PM
  3. 2012: burst, explode attributes to text
    By thoff in forum AMEP General
    Last Post: 2011-05-24, 09:01 PM
  4. burst vs explode
    By SCR73 in forum AutoCAD General
    Last Post: 2009-04-23, 03:44 PM
  5. use BURST instead of EXPLODE
    By ceekayem in forum AutoCAD Tips & Tricks
    Last Post: 2006-01-20, 05:21 PM
