Results 1 to 10 of 12
Thread: Upgrading to XP
    2004-08
    13
    Default Upgrading to XP
    I have been informed by our IT department that we are looking to upgrade our operating system from the current Windows 2000 to Windows XP. Last fall we upgraded AutoCad from 2004 to ADT 2005 and I suspect we will be staying with that for a while.
    My question . . . are there any "issues" that I should be aware with regarding this upgrade from a cad standpoint? I would like to make the "higher up" aware of any glitches that may affect either productivity or cad support.
    Thanx,
    Joseph Navin
    Excel Engineering
    2001-05
    Austin, TX USA
    2,201
    Default Re: Upgrading to XP
    You shouldn't have any problems as long as everything is a nice clean install.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    Turlock, CA
    5,659
    Just make sure that cad users belong to the Power Users group.
    C:> ED WORKING....
    2004-08
    13
    Ed,
    Excuse the dumb question . . .
    What do you mean by Power Users Group? Is this an actual users group or just a loose term to define the serious cad users?
    Joe
    2001-12
    St. Louis
    5,302
    Talking Re: Upgrading to XP
    Quote Originally Posted by joe.n
    Ed,
    Joe
    It's a classification within windows that sets certain rights for users.
    look under your control panel > user accounts and you can see the options in there. You'll see the user accounts on the pc: the user name, the domain and their group (user, power user or administrator).
    good luck with your upgrade.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    Turlock, CA
    5,659
    Thanks Melanie.
    Your IT guy would probably do this anyway, but I would seriously reccommend rebuilding the pc and installing XP fresh, as opposed to "upgrading". Its more work, but well worth it as far as stability goes.
    C:> ED WORKING....
    2004-08
    13
    Thanx for the input so far.
    I spoke with our IT guy right before lunch and he said that this will be happening in the next couple of weeks so I am going to come back next week and see if there are any additional comments. He also mentioned that we will be running Winsdows XP Professional, service pack 2 (if that matters) and that we will be receiving new pcs so it should be a fresh install.
    Thanx, again
    2004-07
    Detroit Michigan
    2,508
    I remember there being some sort of issue between Windows XP Service Pack 2 and AutoCad. I would suggest making sure you have all the most current AutoCad patches.
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by rhall.72202
    The only issue I know of was the Windows firewall blocking the communication center from contacting the Autodesk server. If you don't use the firewall you shouldn't have a problem.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    13,654
    Quote Originally Posted by Ed Jobe
    Hi
    I believe that is only a requirement for AutoCAD 2002 users or below...
    ID: TS70312 - Permissions required to run on Microsoft® Windows® XP Professional
    Below quotes come directly from AutoCAD 2004 reviews...
    Quote Originally Posted by JTB World
    Support for installation without power user rights.
    Quote Originally Posted by DotSoft
    Operating Systems: AutoCAD 2004 is now Windows XP certified, and runs fine on Windows 2000 as well. Power user privileges are no longer required. Operating systems such as Windows 95/98/Me are not supported. In our opinion these operating systems were never stable enough to be considered for AutoCAD anyway.
    Have a good one, Mike
  1. 2013: Trouble upgrading
    By jagnag1359425 in forum AutoCAD LT - General
    Last Post: 2012-10-30, 04:00 PM
  2. Upgrading to 2011
    By lee.johnson in forum AutoCAD Plotting
    Last Post: 2011-05-06, 11:38 AM
  3. Upgrading to 64 bit O/S?
    By ccowgill in forum AutoCAD General
    Last Post: 2009-07-18, 01:40 PM
  4. Upgrading
    By tcdavis in forum DV - The 3rd Dimension
    Last Post: 2008-03-31, 08:14 PM
  5. Upgrading ADT?
    By StephenJ in forum ACA General
    Last Post: 2005-12-23, 03:06 AM
