i have 2 questions on xdata..
1.how to append a data to the xdata list already attached to an entity?
2.how to remove xdata from an entity?
thanks in advance..
regards,
SANTHOSH
thanks in advance..
regards,
SANTHOSH
Do you want to append to the same application name?
Do you want to remove for all application names or one specifically?
Regards - Nathan
nathan,
1.the data is to be appended to the same application.
2.the entity is to be rid of xdata of all application names(including the application itself)..
hope this makes it more clear..
thanks for responding...
santhosh
1. You will need to use the GetXData method to return the current XData and append the new data to the returned arrays then pass the arrays to the SetXData Method.
2. Go to www.ACADX.com and in the menu down the side under Visual Basic is a ClearXData routine.
Regards - Nathan
