I have been able to recreate the power exit.
Insert this block into a blank drawing, scale it non uniformly, and try to explode it
Hi
Early testing is pointing towards Block "ACMAP_ANN_TEMPLATE_OWNER INFO" causing the problem / issue... Remove "ACMAP_ANN_TEMPLATE_OWNER INFO" from the equation and the problem / issue disappears... more later, possibly.
Have a good one, Mike
Thanks Mike,
A little more background on what I know...
If the block is removed the problem is no longer there, however, in regards to the Power Exit, it is a way to recreate it. Is there anything that Autodesk might be able to do to fix it, at least in this instance? I know the former post that we were discussing this in, it was stated that if it couldnt be recreated, AutoDesk wouldnt acknowlege the Power Exits existance as a problem (no error, nothing to fix).
Thanks again,
Chris
HiOriginally Posted by ccowgill
If you are using AutoCAD 2004 or above, try using the following...
<snip>
Error Reporting utility let's you send in reports to Autodesk if AutoCAD crashes. Do it and make the next Service Pack or Release more stable. If AutoCAD ends unexpectedly, and the Error Report message is not displayed, make sure the REPORTERROR system variable is set to 1.
</snip>
