Results 1 to 6 of 6
Thread: Portable License Utility
    23
    Default Portable License Utility
    I get an error message when I try and execute the Portable License Utility program in Revit. It tells me to uninstall, reboot and install again which I did and still get the same error message. Has anybody out there had this happen to them
    TIA
    Revit Moderator Tom Weir's Avatar
    2003-11
    639
    Default Re: Portable License Utility
    John,
    So you don't get into the dialog box at all? I am not having a problem up here in LA. Did you install as a single installation? Is the license active or are you on the 30 day license?
    Tom Weir
    Los Angeles
    p.s. great to see you accessing the forum...
    2004-05
    Santa Barbara, Ca.
    40
    Arrrrr -having the same problem. Anybody figure out this issue?
    100 Club rod.74246's Avatar
    Brisbane Oz
    135
    Had the same issue. The only thing that fixed it was a complete re-install.
    2004-06
    94
    I had just (30 min ago) the same problem when changing to a new computer, though I removed and reinstalled the program. Fortunately REVIT allowed me to re-register with my old serial number, otherwise there had been a serious delay in work. Perhaps I would have to manually remove all the Revit files and just not remove and reinstall the program in order to get the Portable licence utility fixed.
    2004-05
    Santa Barbara, Ca.
    40
    For me this problem was being caused by the automatic deployment.
    I re-installed the program from the install file instead of the deployment shortcut, then transfered the license, then re-installed from the deployment for the presets.
    That worked fine on 2 computers.
  1. Portable License Utility problem
    By fangelo in forum Revit Architecture - General
    Last Post: 2008-12-20, 10:28 AM
  2. Portable License Utility
    By nat in forum Revit Architecture - General
    Last Post: 2007-08-08, 08:27 PM
  3. Portable License Utility - Tracking?
    By Lklock in forum CAD Management - General
    Last Post: 2005-09-26, 04:13 PM
  4. Portable License Utility
    By gdaniels in forum ACA General
    Last Post: 2005-08-02, 09:29 PM
  5. Portable license utility
    By wimmerea in forum CAD Management - General
    Last Post: 2005-01-21, 06:08 PM
