Textmask works, perfectly, in the 'child' CAD file. But, when X-ref'd into the Parent file, the text mask has a visible rectangular perimeter. How do I delete this? Prior appreciation for help...
Tried all IMAGEFRAME options with Regen in both Parent and Child files (9 permutations)...doesn't seem to make a difference.
Hi
Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
ID: TS27535 - Boundary frame visibility for Wipeouts in xrefs and inserted drawings
ID: TS2838 - Text mask: Cannot select frame
ID: TS1450 - Text mask: Removing
Have a good one, Mike
