chrisw.94380
It doesn't show the command name and when I bring up the text window it does not do it either. It seems as though commands that are specifically for land desktop do not have a command name that I can find. Is there a way to define a command without knowing the original command if there is one. Or another way to run that command in a lisp routine. thank you
check the MENUECHO System Variable
Type: Integer
Not saved
Initial value: 0
Sets menu echo and prompt control bits. The value is the sum of the following:
1 Suppresses echo of menu items (^P in a menu item toggles echoing)
2 Suppresses display of system prompts during menu
4 Disables ^P toggle of menu echoing
8 Displays input/output strings; debugging aid for DIESEL macros
