Thread: redefining blocks
    2004-12
    42
    Default redefining blocks
    I have several blocks that i have created with custom attributes
    I have been asked to modify several of these blocks and i seem to be having a problem
    when i try to resave them
    when i orginaly saved the blocks i selected each attribute in the order that i wanted them to be in
    now if i try to modify them in anyway the attributes are getting mixed up....
    how can i make modificatins to the blocks and not mess up the attributes ?????
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    Default Re: redefining blocks
    Have a look at this thread, and following any links within.
    2004-12
    42
    thanks for the help
    Do you know of any other way to work with the attributes in a block other than the order in which they are saved...maybe by the tag
    I am not sure if this is possible but thought i would ask...
    here is what i am currently doing....
    ThisDrawing.ModelSpace.InsertBlock(vMaxCoord, _
    "c:\weldedfilterflange\" + filterdrawing, vScale, vScale, vScale, 0)
    If filterdrawing = "spclrectfilterflg.dwg" Then
    varAttributes = BlockRefObject.GetAttributes
    varAttributes(0).TextString = OutsideWidthtxt + """"
    varAttributes(1).TextString = "(" + txtSpacing3 + ") " + "SPCS " + "@ " + txtSpacing4 + "=" + txtSpacing5
    varAttributes(2).TextString = InsideWtxt + """"
    varAttributes(3).TextString = Spacing1txt + """"
    varAttributes(4).TextString = Spacing2txt + """"
    2002-01
    jUSt Here (a lot)
    9,135
    You may want to ask this in the VBA forum. You will probably get more help there with this type of question.
    13,657
    Hi
    Have a browse of the following post...
    RE: Adding addtional Attributes
    Have a good one, Mike
  1. redefining mvparts blocks
    By mwalker.87963 in forum Parts Builder
    Last Post: 2010-09-17, 02:11 AM
  2. Redefining Blocks
    By Doodlemusmaximus in forum AutoCAD General
    Last Post: 2008-02-26, 12:32 PM
  3. Redefining old Blocks to new Dynamic Blocks
    By dgriessmann.86073 in forum AutoCAD General
    Last Post: 2006-10-31, 09:41 PM
  4. Redefining your Dynamic Blocks
    By whdjr in forum AutoCAD Tips & Tricks
    Last Post: 2006-06-27, 02:51 PM
  5. Dynamic Blocks Not Redefining
    By Rico in forum Dynamic Blocks - Technical
    Last Post: 2006-02-07, 07:50 PM
