Hi all,
Need to turn off grids in site plan sheet but leave them on in main plan sheets - please help - urgent!!! Thanks.
kwong
Hi all,
kwong
Activate the site plan view on the sheet, then go to Visibility/Graphics, and turn off the Grids for that view.
That simple is it?
Thanks Scott!
kwong
Actually, if I'm understanding your question correctly, you want a site plan placed on a sheet to not show grids, while other site plan view (s) do show grids.
In that case, you would use two views of the Site Plan. Say one view is called " Site ( No Grids ) ". That view has the grid visibility turned off and that view is placed on a sheet. You duplicate that view, rename it " Site - Grids " and turn the grid visibility on in that view, That second view is placed on your other sheets.
Yes beegee, you're right, because normally the site plan would have been drawn on the default site plan, but in our case it was drawn on the ground floor and therefore the GF plan was used for both site & gf plan. It's been fixed now that the rush is over. Thanks.
kwong
