Results 1 to 7 of 7
Thread: Curtain Walls: Creating Patterns
    2001-12
    Irvine, CA
    7,567
    Default Curtain Walls: Creating Patterns
    Reading a post in the Autodesk ng's about curtain walls reminded me of something about the new curtain wall styles, Exterior Glazing and Storefront. These styles can have predefined patterns, mullions and panels. Since we can swap out panels with other walls, we can also swap out panels with other curtain walls.
    Imagine a curtain wall that uses a large 12x6 pattern and large mullions. Also imagine we want a smaller 3x3 pattern with smaller mullions. That's a lot of grids to put in and assign mullions. If you set up two different curtain wall styles and assign the larger to use the smaller as panels you get the final result with a lot less effort. Also if you overide the settings of individual panels you can substitute yet another curtain wall pattern.
    The attached is a quick representation of what I'm talking about. Hope it helps!
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: Curtain Walls: Creating Patterns
    Steve,
    A more elegant, and consistent approach than what is outlined in this thread. Also permits scheduling of vent windows and doors placed this way, correct?
    http://forums.augi.com/showthread.ph...hlight=curtain
    2005-10
    16
    Question Re: Curtain Walls: Creating Patterns
    Quote Originally Posted by steve_stafford
    um... maybe I'm slow, but I don't see a way to make predefined patters, especially with mullions, and panels? Can you set this in the family-- I don't see the option anywhere, except for a Building Code description which is more cryptic than anything else.. Can you post a screenshot or point me towards a tutorial where you can do this? thanks.
    a
    All AUGI, all the time Allen Lacy's Avatar
    2003-04
    Richmond, VA
    545
    In Help > Curtain Walls >Grid Placement.
    2005-10
    16
    Red face Re: Curtain Walls: Creating Patterns
    in those setting described in the help file (which I had read already) there is only the possibility of a simple one or two axis grid, without that much control of more complex layouts.
    the previous post made it sound like you could specify say, primary grid lines every 3' (easy enough), then secondary grid lines at 3', 7', and 9'-6" (which you can't do with the settings pointed outin the help file, as that's 3 seperate spacings) PLUS mullion types. that would be a great start.
    right now I have to set the 3' primary grid, then add the aforementioned grid lines in by hand in elevation. not to mention the complex mullion pattern. not fun for a multi story building... it almost seems that CAD is faster...
    a
    ps- it's fully possible that I'm missing something big
    2001-12
    Irvine, CA
    7,567
    What version are you using? This is from 8.1 forward
    2005-10
    16
    darn-- I'm using 8.0. that alone sounds like it would be worth upgrading. unfortunately, I'm in a school environment, so I don't think I can just upgrade as if it were my computer. but I may try... thanks for the clarification, steve
  1. Replies: 0
    Last Post: 2015-08-07, 03:55 PM
  2. Replies: 0
    Last Post: 2015-08-07, 03:48 PM
  3. Replies: 0
    Last Post: 2009-01-31, 03:55 PM
  4. Use Walls with Surface patterns for curtain walls in Early Design
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2009-01-13, 10:21 PM
  5. Custom curtain wall panels on curved and slanted curtain walls/systems
    By AP23 in forum Revit Architecture - General
    Last Post: 2008-06-02, 09:08 PM
