Thread: Downsizing
    2015-10
    Ontario
    68
    Question Downsizing
    Hello
    I use MDT V.6 for fixture design, sometimes when creating my layout views I am unable to resize a viewport ie the iso vp.
    It would appear by the dotted lines that appear when I go to edit the viewport that the setting has taken but the actually resizing hasn't occurred???
    Wassup with that. Thanks for any help.
    2001-12
    Pittsburgh, PA
    71
    Default Re: Downsizing
    I don't know if this is what you are looking for but I use V5.0 and this is what I do.
    Turn on the "Views" layer and stretch the viewport to the desired size. The dotted lines will still be in the original location but the viewport will be different. Then just turn off the "Views" layer when done.
    Hope that helps.
    Paul
    2015-10
    Ontario
    68
    Thanks Paul I'll give that a try,
    however I'm not sure how clear I was, The viewport itself can be resized but the actual display of the model in the viewport doesn't want to play along. That is it remains unchanged.
    Thanks, I will fiddle around some more with it.
    2001-12
    Pittsburgh, PA
    71
    I thought you were talking about changing the size of the viewport because its too big and overhangs the titleblock throwing the print out of whack or something.
    Have you tried to right click on the view that you want to change and select edit. This brings up the "Edit Drawing View" dialog box. In the upper left hand side there is a section for scale. Change that to your desired scale. That will change the model in the viewport.
    Hope that helps
    Paul
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,095
    Is your viewport locked?
  1. downsizing viewports
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2010-07-07, 11:16 PM
