Thread: Baluster to tread
    2003-05
    Colorado Springs, CO
    97
    Default Baluster to tread
    I looked around previous forums, but I can't seem to find if there is a way to have the bottom of the baluster attach to the tread. I think Revit will let me do this. But I'm not sure how. Anyone have any wisdom regarding this?
    2003-05
    5,153
    Default Re: Baluster to tread
    Hi Trent,
    Open the baluster family. Locate the cut extrusion ( cutting the balusters to the railing and stringer angles ) Edit the extrusion and delete the lower portion that provides the cut to the stringer line. Delete the lower miscellaneous Ref Planes and lock the baluster bottom to the Level Ref Plane.
    Rename and load the baluster into the project and substitute that baluster for the previous in the railing family.
    HTH
    I could stop if I wanted to zanzibarbob7's Avatar
    2004-08
    Wayne, ME
    444
    BeeGee,
    I have been trying your method with a standard monolithic stair and square baluster/railing as comes from one of the default selections. There is something I am missing. I got it to work once but I should be able to make the changes in a matter of less than a minute. I am not. Here is how I proceeding:
    Open the square baluster family
    Save with new name
    Locate void extrusion then delete
    Delete lower reference plane
    Align and lock the bottom of baluster to Ref. Level
    Save and load into project
    Edit bluster and select newly created baluster, Apply then OK
    I still do not get the balusters to reach the tread. Where am I going wrong?
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Check to make sure the rail sketch is drawn on the boundary of the stair. Seems to stop working if its been relocated at all, and certainly won't extend if the balusters are not actually over the stair.
    HTH.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
  1. 2015: adjusting spacing while using "Use Baluster Per Tread On Stairs"
    By jledgewood in forum Revit Architecture - General
    Last Post: 2015-09-01, 08:27 PM
  2. 2015: use baluster per tread on stair (with no top rail?)
    Last Post: 2015-08-28, 07:05 PM
  3. What controls the Baluster Per Tread spacing?
    Last Post: 2010-03-02, 05:30 PM
  4. Stair - extend baluster feet to tread?
    By ws in forum Revit Architecture - General
    Last Post: 2007-12-18, 08:30 PM
  5. Baluster per tread?
    Last Post: 2005-07-12, 08:47 PM
