Thread: Room Bounding check box when drawing walls
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Room Bounding check box when drawing walls
    I would love the room bounding check box to appear on the options bar when you use the wall command. I find myself spending a lot of time having to draw walls, then come back and select them and edit their properties.
    Scott D. Brown, AIA
    BECK
    AUGI Addict bowlingbrad's Avatar
    2003-11
    Chicago
    1,233
    Default Re: Room Bounding check box when drawing walls
    I think there should also be a disallow join checkbox as well.
    Scott,
    Have you ever tried using the view property that only joins similar walls? I am seeing more and more that I may need to try this.
  1. Conceptual mass family walls NOT room bounding
    By cslaten78249688 in forum Revit Architecture - General
    Last Post: 2012-09-06, 09:08 PM
  2. Room Bounding Walls NOT Bounding Rooms??
    By jkady in forum Revit Architecture - General
    Last Post: 2009-09-30, 04:57 PM
  3. Problem with non-room bounding walls
    Last Post: 2007-07-22, 10:15 PM
  4. Doors on not room bounding Walls
    By jarkko.rauvanlahti in forum Revit Architecture - General
    Last Post: 2005-09-23, 01:26 PM
  5. Can in-place walls be room bounding?
    By patricks in forum Revit Architecture - Families
    Last Post: 2005-05-06, 11:34 AM
