Results 1 to 9 of 9
Thread: Plant Library---controlling groundcovers?
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Plant Library---controlling groundcovers?
    I don't know if the groundcover plant is what I truly need, but the ability to control it would be nice. Does anyone know how? How to know what size it will render?
    A more important question is if there is a feature that I can use a plant from the plant library for a linear vine like creaper? I am thinking along an open truss?
    Ok, like along the structure in the picture?
    ohhh boy, sometimes I start threads that people find difficult to participate in.....
    I hope I am wrong!!!
    Peace,
    All AUGI, all the time Max Lloyd's Avatar
    2004-07
    London, England
    782
    Default Re: Plant Library---controlling groundcovers?
    No obvious solution springs to mind.
    What if you made a plant that simply consisted of say 4-5 leaves (not site based) and arrayed it around your structure. Could work well?
    2003-09
    1,907
    Luigi,
    Here's a work around I did on a little presentation to a city for a metal building. Note that when you overlap the map for masking on the extrusions you get a "black" image. Look at the building image closely and you'll see the flaw, but in this case it comes off as a type of shadow.
    This should give your creative side some ideas. The zip file has the jpgs and vine.mlb
    2015-11
    Royal oak, Michigan
    1,513
    Thank you both for responding.
    Ski, you probably saved my quite a few hours!!!
    Thanks again....
    Peace!!!
    2015-11
    Royal oak, Michigan
    1,513
    Thanks Ski, I realized after opening it that you are rendering a solid with the vine material. I just need to create the solid as close as I want...
    Do you have any suggestions about groundcovers? They're nice, but I don't know how to control the size...
    Take care,
    Luigi
    2015-11
    Royal oak, Michigan
    1,513
    Thanks, find below my results....not great, but not too bad....
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    ground cover is a 3ft x 3ft square approx. so I open a plant family and make a symbol line this size, then you can copy it around.
    Scott D. Brown, AIA
    BECK
    2015-11
    Royal oak, Michigan
    1,513
    are all square, or it depends? I thought in my last attempt (an accustudio groundcover) it seemed to be a rectangula proportion
    2003-09
    1,907
    Frame posted a grass scenario here Not sure if it'll help with your ground cover issue.
  1. Replies: 1
    Last Post: 2006-03-03, 05:01 PM
  2. Accessing the Plant Library in Revit Building 8.1
    By David J Krope in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-01-27, 03:54 PM
  3. Accessing the Plant Library in Revit Building 8.1
    By David J Krope in forum Revit Architecture - General
    Last Post: 2006-01-25, 11:57 PM
  4. Questions about making a RPC plant library
    By hdjohnson in forum Revit Architecture - Families
    Last Post: 2004-12-08, 11:08 PM
  5. Accurender plant library
    By Nic M. in forum Revit - Rendering
    Last Post: 2004-04-02, 04:52 PM
