Results 1 to 7 of 7
Thread: Dimension points do not move when using the Move command
    Member sudhirkizhakoote's Avatar
    2005-10
    24
    Unhappy Dimension points do not move when using the Move command
    i am in a dilema how to resolve my problem, i've drawn the archetecture drawing of a G+1 Villa with diamension. the problem is i cannot move the drawing from one place to another.If i give select all and move all the entities will move except some of the diamension points!!!! that will retain in the original position and the line with diamension text will extend up to the new position.... there is anybody encountered this problem before.... please help me...
    13,656
    Default Re: Dimension points do not move when using the Move command
    Hi "sudhirkizhakoote" (Sorry, I don't know your real name)
    Please note I have *moved* this thread from the AutoCAD Plotting forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Question Re: Dimension points do not move when using the Move command
    Hi
    Are all relevant Dimension defpoints included in your selection set when using the _.Move command?
    If still no joy, please post a sample drawing file that exhibits the behaviour you have described above.
    Have a good one, Mike
    Last edited by Mike.Perry; 2006-11-11 at 08:51 AM. Reason: Correct post formatting issues.
    2004-08
    Iron Station, NC
    3,198
    are you sure the dimensions are not on a locked layer?
    2005-10
    24
    Unhappy Re: Dimension points do not move when using the Move command
    i am in a dilema how to resolve my problem, i've drawn the archetecture drawing of a G+1 Villa with diamension. the problem is i cannot move the drawing from one place to another.If i give select all and move all the entities will move except some of the diamension points!!!! that will retain in the original position and the line with diamension text will extend up to the new position.... there is anybody encountered this problem before.... please help me...i am attaching the sample of the file
    0,0,0 The Origin
    8,570
    The dimensions that do not move are all Rotated dimensions.
    If you replace them (re-dimension) with Linear dimensions, the new dimensions do move.
    HTH
    13,656
    Please note I "merged" your two threads that deal with exactly the same issue / problem.
    In future please do not create multiple threads that deal with the same query, it makes the forum process that much more difficult for everyone concerned.
    Thanks, Mike
    Forum Moderator
  1. Move a group of points
    By eduley in forum Civil 3D - Civil Design Companion - General
    Last Post: 2015-08-31, 04:24 PM
  2. Modify MOVE command to allow multiple base points
    By markduffany374040 in forum AutoLISP
    Last Post: 2013-04-30, 03:09 AM
  3. Move Points and Figures
    By SRBalliet in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-20, 11:47 AM
  4. I dont want my points to move in the drawing
    By jenniferchavez in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2007-09-13, 03:17 AM
