Results 1 to 10 of 16
Thread: AutoCAD Layer Standards Manager
    2005-03
    5
    Default AutoCAD Layer Standards Manager
    Does anyone understand how to use - Layer Standards, Key Styles, and Overrides built into AutoCAD 2005 and later. I would like the Company Layer Standards to be available in the Template drawing but setting a new one up is a mystery
    Setting up a dwt is not the issue. The isssue is - creating a NEW layer standard using:
    100 Club tlewald's Avatar
    2003-01
    USA
    144
    Red face Re: AutoCAD Layer Standards Manager
    Hi kenb,
    it's actually pretty easy - setup a new drawing the way you want it and then do a "saveas".
    Save your new (blank) drawing after you have it the way you want it with a .dwt extension and then call that new .dwt file every time you start a new drawing.
    Feel free to write me if you need some more help!
    2001-12
    St. Louis
    5,347
    Talking Re: AutoCAD Layer Standards Manager
    Quote Originally Posted by kenb
    I realize that this is a CAD Management issue, but, for the question of setting up a template drawing, I am going to move this to this forum as I believe it will be better served here.
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use BricsCAD, Revit, & Tririga, too)
    Technical Editor
    13,656
    Question Re: AutoCAD Layer Standards Manager
    Hi
    Are you referring to a DWS (CAD Standards) file?
    Have a good one, Mike
    2005-03
    5
    Default Re: AutoCAD Layer Standards Manager
    No. The dws is for standards enforcement. Hidden inside the 2005 Layer Manager is a Standards utility that ADT uses and is now available in AutoCAD 2005. It includes an AIA set of Layer Standards and there is an option to create new Layer Standard Sets. Problem is it's a mystery to run.
    13,656
    Hi
    Please direct me to this new feature found in vanilla AutoCAD 2005...
    2005-03
    5
    Check out the dwf
    13,656
    Check out the dwf
    Hi
    That is not vanilla AutoCAD 2005.
    That is Map 3D.
    Vanilla AutoCAD 2005 does not have such functionality.
    Please let me know which Autodesk product forum you would like this thread moved to, I will then happily take care of it.
    2001-12
    St. Louis
    5,347
    you know, I realize that title bar says map3d, but, the icon doesn't look like the map icon, and I don't see such a button in my layer manager. am guessing this might be land desktop?
    Quote Originally Posted by Mike.Perry
    Hi
    That is Map 3D.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    13,656
    Quote Originally Posted by Wanderer
    Hi
    Thanks for the info...
    Whichever vertical Autodesk product it is, it most definitely is not vanilla AutoCAD.
    We just need "kenb" (Sorry, I don't know your real name) to tell us which vertical Autodesk product he / she is using; we can move this thread to the appropriate Autodesk product forum.
  1. Autocad layer standards
    By sissela in forum CAD Standards
    Last Post: 2011-12-08, 07:34 PM
  2. Standards manager layer walk
    By Liamnacuac in forum AMEP Wish List
    Last Post: 2010-04-12, 10:52 PM
  3. Replies: 11
    Last Post: 2009-02-27, 04:25 PM
  4. Layer Manager and AutoCAD 2008
    By slaga in forum AutoCAD General
    Last Post: 2008-04-29, 12:14 PM
  5. Where is Layer Manager in AutoCAD 2007
    By mickb in forum AutoCAD General
    Last Post: 2007-04-04, 04:58 PM
