Results 1 to 10 of 15
Thread: uploading blocks to the web
    2005-10
    Default uploading blocks to the web
    Looking for procedures or pointers in adding symbol libraries onto the company web site for several users in different locations to access.
    2001-12
    St. Louis
    5,406
    Talking Re: uploading blocks to the web
    Quote Originally Posted by cody.huston
    That's a good question. I'm sure there's probably various ways to accomplish something like this.
    Do you already have a website (intranet or internet?) where files are shared, or is this something that would be created just for this purpose?
    are you planning on having one file containing an entire library, or each part/block as it's own file to be downloaded as-needed?
    Are these various locations under the same management?
    There's a thread over in the Autodesk groups that might interest you... adding content to design center online.
    sharing whatever files I do here is either done via email for the guys in my facility, or via our collaboration website (used to be buzzsaw, now it's something else) for our contractors and corporate entities.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2005-10
    Default Re: uploading blocks to the web
    Wanderer,
    Yes we already have a website that we all access for time sheets and etc. a share-point website.
    Each block will be an individual file.
    All locations are under the same management
    2001-12
    St. Louis
    5,406
    Wanderer,
    hmm, perhaps you'd like to look at something like iDrop?
    from acad help:
    i-drop is a drag-and-drop method of inserting content from the Web into your current drawing. Using i-drop, you can easily insert content such as drawings and catalog items into an open drawing. Specific examples of i-drop content that you can insert include a block of a chair or window or a bitmap of a linoleum sample.
    You can use the Publish to Web wizard to create a web page that has i-drop-enabled content for a drawing file. For details about other ways to create a web page that has i-drop content, see the information about i-drop on the Autodesk website
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,095
    The i-drop technology will not work with Firefox due to it being an activeX application.
    But I could be wrong since I haven't learned the technology yet.
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by richardl.25628
    You are correct.
    2002-01
    jUSt Here (a lot)
    9,095
    Quote Originally Posted by Glenndp
    You are correct.
    Can we put that on the calendar?
    2001-12
    St. Louis
    5,406
    That's like twice in one year...
    It seems that I have read somewhere that IE will be reworking their specs to meet some sort of standard with the next version, then it seems that all IE-specific technology will have to be re-worked and upgraded to comply at that point.
    erm... I'm sure mp will chime in here and tell me if I've got that bit right?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    0,0,0 The Origin
    8,570
    Quote Originally Posted by Wanderer
    When did Micros**t ever adopt a "standard" standard and not alter it?
    2002-01
    jUSt Here (a lot)
    9,095
    I know I must be getting better.
    That would be a nice thing of for IE to be compliant.
  1. Uploading attachments
    By Opie in forum Forum Tips & Tricks (Read only)
    Last Post: 2014-10-16, 02:15 PM
  2. Uploading problem
    By Depeshrai in forum Revit Architecture - General
    Last Post: 2009-12-16, 01:57 PM
  3. Uploading to RUGI
    By adegnan in forum Revit Architecture - General
    Last Post: 2004-04-22, 12:01 PM
