Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Construction Documents
    2003-09
    1,907
    Default Construction Documents
    Put this here to remind the new comers to Revit that the 2d drafting aspects of Revit are easy to work with too. It takes a change of mindset from the ADT days, but very easy to draw with. Perhaps a forum on construction documents would be eventually in order, or perhaps put this in Revit - In practice?
    Also- forgot to mention. These are NOT Acad drawings just converted. These were generated using the detail option (callout), then the model turned off in the view.
    2003-11
    442
    Default Re: Construction Documents
    Quote Originally Posted by Skisouth
    I thought there used to be a construction documents sub-forum? See THIS thread. It looks like Chris created one, but it was later deleted at some point? Anyway, I think it is a good idea.
    2003-09
    1,907
    Yeah, was going to post these there, but - as you say - not to be found.
    I could stop if I wanted to kpaxton's Avatar
    2004-12
    Sarasota, FL
    493
    Ski-
    Appreciate this Post man! This is probably one of the hottest issues with the "Old Guard" in our office. "Revit can't do detailing!" they bemoan. "I best do them in AutoCad," they snicker. "If you would only learn the program," I reply.
    Keep up the good work and repeat after me...
    Repeating Details are your Friend!
    I'd love to see a forum on this topic, by the way. It'll only help bolster the fact that these can be done (quickly and efficiently too!)
    -Kyle
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,285
    Great detailing Ski... very nice work
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
    2003-04
    Chino, CA
    4,756
    Ski,
    Permission to share your images with my AU detailing class? (With credit to you, of course...)
    Thanks!
    I could stop if I wanted to Lashers's Avatar
    2003-07
    Rickmansworth, UK
    423
    Great idea Ski! I use to enjoy (wierd) the occasional posting in the CD page, just because it was not used much, doesn't mean that it did not have a use . . . .
    Thought I would throw one in - for convincing others . .if it is any good! Fdn-floor-wall (steel frame) detail. All Revit
    I could stop if I wanted to Shaun v Rooyen's Avatar
    2005-02
    337
    Ski; Lashers, great work!!!!
    Nice to see some, using Revit properly!!
    My question to both of you is, how much Detail line work are in those views?
    or do you build the detail component families.
    I just find linework heavy, and would much rather build the detail family. Re-use!!
    100 Club JTF's Avatar
    2003-04
    Welland, Ontario, Canada
    169
    I could never understand what the argument was all about.
    What more do you need then lines and an offset option to create details with anyway.
    I have always found it easier to create details in Revit when required.
    And the details posted here only prove this.
    And by the way awesome details guy's.
    2003-07
    Rickmansworth, UK
    423
    Thanks guys, that was an early one . . Zeds, to answer you query that detail was all Regions and Linework - still easy to reuse with the copy/paste, but I agree, i am starting to use Detail Components more now and they are a definite benefit.
    So guys, how about those construction pages???
  1. Mirrored Building Construction Documents
    By darkstknight1523 in forum ACA General
    Last Post: 2010-05-03, 09:59 PM
  2. Use of 3D images in Construction Documents
    By dc.109967 in forum Revit Architecture - General
    Last Post: 2008-08-21, 11:33 AM
  3. Quality Construction Documents
    By paul.meco in forum Revit Architecture - General
    Last Post: 2006-09-15, 05:38 AM
  4. Split Construction Documents
    By stuntmonkee in forum Revit Architecture - General
    Last Post: 2005-05-19, 04:27 PM
