Thread: Material Hatch Patterns
    2003-03
    Alberta
    260
    Default Material Hatch Patterns
    I wish that in the Material definitions in the styles of a part you could assign a hatch pattern to use for that material. You can assign a colour style to use for visualization, a hatch style would be nice for use in drawings.
    When I hatch a part or assembly view it could then automatically use the hatch that's in the Hatch Style. Thus if I have a steel column protruding from a concrete block when I create a break out view or other I get different hatches for the different materials.
    Benjamin
    2003-03
    Alberta
    260
    Default Re: Material Hatch Patterns
    It would also be nice if you could apply a hatch pattern to be used for specific faces for color styles. When I have something like expanded metal or checker plate I like to use a hatch in my drawing to help aid in communicating the different types of materials.
    If there where a specific hatch associated with a face for color style I wouldn't have to manually add these hatches to the drawing. They would simply appear when I create the view.
    The hatches might be controlled in a similar fashion to the Get Weld Annotations.
  1. 2015: create/ convert hatch patterns (.pat) to revit fill patterns
    By jledgewood in forum Revit Architecture - Tips & Tricks
    Last Post: 2015-06-01, 11:48 PM
  2. 2015: Hatch Patterns
    By vtmiii in forum AutoCAD General
    Last Post: 2015-03-27, 04:57 PM
  3. Grey hatch underneath material hatch
    By sconlin in forum Revit - Platform
    Last Post: 2009-07-09, 05:27 PM
  4. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  5. Hatch Patterns
    By hydestone2002 in forum AutoCAD LT - General
    Last Post: 2005-09-26, 08:10 PM
