Thread: Can't access to AutoCAD 2000 after installation.
    2004-10
    5
    Unhappy Can't access to AutoCAD 2000 after installation.
    Error message popup once enter to ACAD 2000: Security system (hardware lock or network license) is not functioning or inproper installation. Is ACAD 2000 need toggle to run?
    0,0,0 The Origin
    8,569
    Default Re: Can't access to AutoCAD 2000 after installation.
    You probably need to talk to a local dealer.
    Outside of USA/Canada a hardware lock (dongle) used to be required for acad but I don't remember when the dongle was dropped in favour of software locking. I think the international version of A2000 used software locking but, again, there have been two, possibly three, different software locks.
    It's also possible that you have a network version which requires AutoDesk License Manager software to be installed either on the same pc as the client or on another pc on the network).
    John B
    BIM/VDC Management Brian Myers's Avatar
    2003-02
    St Louis, Missouri
    1,815
    Quote Originally Posted by emipang
    The dongle was removed starting with AutoCAD 2002. In 2000 it was still required. I'm not sure of what options you have now that Autodesk no longer supports the product. It used to be that your dealer could provide you with one if you had a licensed version, but it likely would cost you the replacement cost. Today I'm not sure if you dealer can still get these or not... but they'll be the first ones you should contact.
    Brian Myers
    Jacobs: VDC Design Office Lead (BIM Leadership)
    Visit my LinkedIn Profile for more information.
    13,654
    Hi "emipang" (Sorry, I don't know your real name)
    Please note I have *moved* this thread from the Software forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,654
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS36162 - Error: Security system ... is not functioning or improperly installed
    Have a good one, Mike
  1. 2012: Problems in autocad 2012 when opening files from autocad 2011 saved as 2000
    By debora.fernandes in forum AutoCAD General
    Last Post: 2012-06-30, 02:12 PM
  2. Replies: 6
    Last Post: 2009-06-01, 07:10 AM
  3. AutoCAD 2006 Text Editor, restore to AutoCAD 2000 behaviour
    By louis.64641 in forum AutoCAD General
    Last Post: 2007-05-29, 03:58 PM
  4. Autocad 2000 and MS Access (ATP085)
    By purvisp in forum AutoCAD General
    Last Post: 2006-01-18, 03:37 PM
  5. autocad 2000 lt drawing wont open in autocad mechanical 2005
    By garryh in forum AutoCAD Mechanical - General
    Last Post: 2005-06-21, 10:02 PM
