Thread: Better dual-core support
    ACAD Wish List Administration
    2005-06
    1,920
    Default Better dual-core support
    Summary: Dual-core support.
    Description: Better dual-core support
    How Used: In all cad work, in regens.
    Feature Affinity: Other
    Submitted By: Jussi Aho on October 23, 2005
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,145
    Default Re: Better dual-core support
    Does the current WHIPTHREAD AutoCAD system variable improve your regens?
    From AutoCAD 2006 Help File
    Type: Integer
    Saved in: Registry
    Initial value: 1
    Controls whether to use an additional processor to improve the speed of operations such as ZOOM that redraw or regenerate the drawing. WHIPTHREAD has no effect on single processor machines.
    0 No multithreaded processing; restricts regeneration and redraw processing to a single processor. This setting restores the behavior of AutoCAD 2000 and previous releases.
    1 Regeneration multithreaded processing only; regeneration processing is distributed across two processors on a multiprocessor machine.
    2 Redraw multithreaded processing only; redraw processing is distributed across two processors on a multiprocessor machine.
    3 Regeneration and redraw multithreaded processing; regeneration and redraw processing is distributed across two processors on a multiprocessor machine.
    When multithreaded processing is used for redraw operations (value 2 or 3), the order of objects specified with the DRAWORDER command is not guaranteed to be preserved for display but is preserved for plotting.
  1. Core 2 Extreme vs. Xeon Dual Core with Revit
    By angelo in forum Revit - Hardware & Operating Systems
    Last Post: 2006-12-20, 10:33 PM
  2. Replies: 5
    Last Post: 2006-12-04, 09:06 PM
  3. Athlon64 dual core vs
    By ron.sanpedro in forum Revit - Hardware & Operating Systems
    Last Post: 2006-04-04, 02:15 PM
  4. 64bit /dual core support
    By skeinerbk in forum Hardware
    Last Post: 2006-03-29, 09:09 PM
  5. Dual-core support
    By GuyR in forum Revit Architecture - Wish List
    Last Post: 2005-03-03, 01:31 PM
