Results 1 to 10 of 12
Thread: polylinetype attitude adjustments
    100 Club andrewp's Avatar
    2003-06
    149
    Default polylinetype attitude adjustments
    I saw a command recently that would adjust the linetype segments evenly and continuously thru a node... I've lost it... and I can't find the command either...
    thanks...
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,145
    Default Re: polylinetype attitude adjustments
    In the Properties palette (or dialog box if using older versions) you can set the Linetype Generation flag to enable that ability for the selected polyline.
    2003-06
    149
    Richard
    I think that's it... thanks again...
    Drew
    2002-01
    jUSt Here (a lot)
    9,145
    If not come back and tell me to get it right the next time.
    2003-06
    149
    Cool Re: polylinetype attitude adjustments
    Actually, it's ont exactly what I was looking for... I remember seeing on a sight with tips and tricks for AutoCAD... I just can't find that site again...
    2002-01
    jUSt Here (a lot)
    9,145
    Can you explain it a little more then? I'm having some trouble understanding the issue.
    2004-08
    Iron Station, NC
    3,198
    are you referring to the divide, or measure command? you can space objects evenly along a polyline
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Quote Originally Posted by richardl.25628
    When you have a pline that is a hidden or centerline or has some other dash linetype assigned to it, what happens at an intersection? Does the dashed pattern continue or is it interrupted? Make sense?
    2002-01
    jUSt Here (a lot)
    9,145
    Quote Originally Posted by Maverick91
    Did you not read again? I know what it is. The OP said that was not what he was looking for.
    2003-06
    149
    Unhappy Re: polylinetype attitude adjustments
    richard
    i think the command would also adjust the items (such as fence posts) evenly... thus the beginning and the end of the pline look identical... does that make any since?
    i saw it while browsing for something else, and unfortunately, i was in the middle of a project and couldn't take time to play with it...
  1. Hatch Adjustments
    Last Post: 2012-08-17, 01:14 AM
  2. Mass with an attitude
    By bsqwared in forum Revit - Platform
    Last Post: 2009-08-04, 11:17 PM
  3. monitor color adjustments
    By .chad in forum Hardware
    Last Post: 2008-01-15, 02:43 PM
