Results 1 to 10 of 17
Thread: troubles with custom image library
    2005-06
    Idaho, USA
    184
    Default troubles with custom image library
    I am trying to create a custom image library into an .mns file that I have created. I have gotten as far as getting the dialog box to appear, but there is not title to the dialog box nor do the images i have added.
    I have made sure that my support file search path has the network directory where my blocks and images are, but they don't show up. (my blocks and images are named the same thing with the exception of the file extension.)
    Here is what I have so far.
    ***POP2
    [JUB Civil &Library]
    [&Civil Library]$i=JUBCIVIL.scales $i=*
    ***IMAGE
    **SCALES
    [JUB Scale Blocks]
    [2SCALE,2SCALE]^c^c-insert;2scale
    [10scale,10scale]^c^c-insert;10scale
    ***TOOLBARS
    Any help would be great.
    13,657
    Default Re: troubles with custom image library
    Hi
    For starters try the links found in the following couple of posts...
    RE: Customizing AutoCAD 2000i (Pull down menus)
    RE: Creating Slides
    Have a good one, Mike
    13,657
    Hi
    Plus, see if any of the information in the following thread is helpful / useful...
    Toolbar menu buttons override each other
    AUGI Addict Eric Wing's Avatar
    2003-02
    Syracuse, NY
    1,122
    Quote Originally Posted by eleonard
    ***POP2
    ***IMAGE
    **SCALES
    [JUB Scale Blocks]
    ***TOOLBARS
    I have an ATP lesson I did that I will forward on to you when I get out of class here.
    2005-06
    Idaho, USA
    184
    Quote Originally Posted by eew
    If it is the ATP 043 Customizing Menus in AutoCAD 2004 I have it and that is what I have been following, but I get to the part where I add the images and I can't seem to get it to work.
    I am running this off of the network, but I have pathed everything propertly I think.
    Emily
    13,657
    Question Re: troubles with custom image library
    Hi
    Just checking here...
    By the term "images" you do mean Slides ( .SLD files or .SLB slide library files) ?
    13,657
    ***POP2
    ***IMAGE
    **SCALES
    [JUB Scale Blocks]
    ***TOOLBARS
    Hi
    So "JUBCIVIL" is a partially loaded menu group ?
    And "scales" is an image menu from partially loaded menu group "JUBCIVIL" ?
    2005-06
    Idaho, USA
    184
    Quote Originally Posted by Mike.Perry
    Hi
    I believe that is the correct term... I am still learning so much about custom menus and everything.
    13,657
    Hi
    Please see below in-line comments ( blue )...
    ***POP2
    [JUB Civil &Library] <--------------------------------------------------------- this
    [&Civil Library]$i=JUBCIVIL.scales $i=* <- Is JUBCIVIL refencing | and scales |
    ***IMAGE............................................................................................................................|
    **SCALES <--------------------------------------------------------------------------------------this
    [JUB Scale Blocks]
    ***TOOLBARS
    Or are my above comments ( questions ) correct ?
    Active Member tsbykatherine60220's Avatar
    2004-05
    Milwaukee, Wisconsin
    62
    ***IMAGE
    **SCALES
    [JUB Scale Blocks]
    eleonard,
    I think the format you want is
    [2SCALE]^C^C-insert;2scale;
    I don't think the comma and extra text is the correct format.
    If you are going to have very many of these inserts it would be worth it to create a slide library (using slidelib.exe that comes with autocad) and then the format would be
    [JUB_Scale_Blocks (2SCALE)]^C^C-insert;2scale;
    "JUB_Scale_Blocks" is the name of the slide library which will contain the "2SCALE" slide.
    Let me know if this helps, if you need assistance with the slide library just holler
    Rick
  1. 2013 Custom Library Componets?
    By Bill Harper in forum CAMduct General
    Last Post: 2013-02-04, 03:50 PM
  2. 2012: Custom Stair Troubles
    By Limbatus in forum Revit Architecture - General
    Last Post: 2011-08-26, 06:35 PM
  3. How to make image library
    By jim.dahl in forum AutoCAD Map 3D - General
    Last Post: 2009-07-01, 02:16 PM
  4. Custom railing design troubles
    By mthurnauer in forum Revit Architecture - General
    Last Post: 2008-08-08, 05:54 PM
