Thread: Copy and rename an XREF
    ACAD Wish List Administration
    1,920
    Default Copy and rename an XREF
    Summary: The ability to copy and rename an XREF within a drawing.
    Description: Ability to copy xref and give it a different name.
    How Used: I would use this ability to copy an xref in a drawing and give it a different name.
    Example: Lets say that you have an Xref. You want to change the appearance of that Xref. So you would select copy xref and give it a different name. Now you have a child xref that is from the parent xref. Everything is still the same as the parent xref except for the name. Now you can to show it the way you want it. Like turn off layers, change colors and etc… This would be very useful for doing mechanical, electrical, plumbing and framing plans.
    Feature Affinity: XREF
    Submitted By: Brad Crouse on October 26, 2005
    13,656
    Default Re: Copy and rename an XREF
    Hi Brad
    You can already do this... please refer to the links found in the following post...
    RE: Update bound xref
    Mike
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    980
    Thumbs up Re: Copy and rename an XREF
    Quote Originally Posted by Mike.Perry
    Hi Brad
    Mike
    I have read the link and it is all good. But the way that I wish eliminates the need to go into the Xref manager and go through all those step. With this way, you just select copy xref and it prompt you for a new name.
    Brad
    0,0,0 The Origin
    8,570
    I think this is worthwhile.
    Look at it as xreffing the same file multiple times without have to change the name of one insertion before making the next insertion.
    2003-04
    Bethlehem, PA
    980
    This should also have the abiltity to be an overlay or attached.
  1. Rename a copy of a block with attributes
    By rklee in forum AutoLISP
    Last Post: 2010-03-30, 06:33 PM
  2. Copy & rename block definition
    By mcoffman in forum VBA/COM Interop
    Last Post: 2007-02-09, 05:47 PM
  3. To Rename an XREF
    By andrewp in forum AutoCAD General
    Last Post: 2006-08-16, 07:33 AM
  4. generic models copy but rename?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-06-27, 10:17 AM
  5. Copy and rename a block
    Last Post: 2006-02-01, 09:06 PM
