I have a dynamic block with some text attributes that are right justified with a flip action set on them. i have the system variable MIRRTEXT set to 0.
If I type text in and then use the flip command then it works fine and the text is now left justified and aligned correctly. however, If I flip it and then type the text in the attribute field, the text gets out of alignment and the only way to fix it is to do a bedit and click some stuff without changing it, and then save it.
why can't I get my text to align correctly after flipping my dynamic block?
