Results 1 to 8 of 8
Thread: AutoCAD on XP 64 bit
    2005-03
    59
    Default AutoCAD on XP 64 bit
    I have installed Windows XP 64 bit on my AMD Athlon 64 recently and have tried to install AutoCAD 06 with no luck.
    When I start ACAD2006 installation it tells me to install .Net framework 2.0 so I downloaded from MS website and now this .Net installation wants me to install Windows Installer 3.0. So, again, I downloaded Windows Installer 3.1 and now this darn thing wont install on my machine saying that it is for different hardware flatform and I cant find AMD specific installation file on MS website.
    Is there any way that I could go around this problems?
    13,654
    Default Re: AutoCAD on XP 64 bit
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS1053254 - Autodesk products and 64-bit technology
    Have a good one, Mike
    2001-12
    St. Louis
    5,302
    Cool Re: AutoCAD on XP 64 bit
    Quote Originally Posted by ch00su
    I'm sure this won't answer your question, but, it's an interesting discussion: what does/doesn't autocad take advantage of?
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    2005-03
    59
    Unhappy Re: AutoCAD on XP 64 bit
    Dont' you hate it when you have a new gadget in your hand and you can't fully use it?
    Well I guess we all gonna have to wait for next version of AutoCAD.....
    Santa Rosa, California
    13
    Hi, I've been running 2006 with no problems. Maybe switch your chipset to EMT64 (Intel).
    All AUGI, all the time thomas.stright's Avatar
    Texas
    535
    Quote Originally Posted by fiver
    Running on 64 and having AutoCAD actually use it are two totally different things....
    2005-03
    59
    Quote Originally Posted by thomas.stright
    I'm sure that Fiver meant actually USING it on 64 bit machine.
    I've seen from other web sites that ACAD is working as normal in 64 bit machine with XP 64 although CPU information was missing from those posts....I guess all those machines were Intel CPU equipped machines.
    Only if I could get this Windows Installer 3.0 to install on my computer......or there might be someone found a workaround to this..hope that someone see this post and please enlighten me.
    By the way, contrary to ACAD I've installed Revit 8 trial version on AMD64 with XP 64 and it seems to be working fine.
    13
    You might try the following site for help with this:
    http://www.microsoft.com/communities....general&fltr=
  1. 2012: Problems in autocad 2012 when opening files from autocad 2011 saved as 2000
    By debora.fernandes in forum AutoCAD General
    Last Post: 2012-06-30, 02:12 PM
  2. Replies: 6
    Last Post: 2009-06-01, 07:10 AM
  3. Replies: 3
    Last Post: 2007-09-07, 04:36 PM
  4. AutoCAD 2002 - Function / Tool that edits AutoCAD command quick keys
    By stevejlipski in forum AutoCAD Customization
    Last Post: 2007-01-02, 12:07 AM
  5. Replies: 1
    Last Post: 2006-05-14, 06:00 PM
